ground electrical boxes
Discussion in 'Electrical Forum discussion & Blog' started by samlin7, Jan 25, 2008.
  1. samlin7
    samlin7 New Member
    Dec 26, 2007
    hi
    I have 12/2 romex cable coming into a metal electrical box, I was wondering if I need to ground the metal box?
    If so, should i use 12 gauge to ground the box (or any gauge wire) and do they sell the screws to attach to the metal box so I can ground it? Or can I use any screws I see in the metal box?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If the ground wire will not reach to the threads where the ground screw goes then pig tail with yellow wire nut and a peice of #12 bare wire to it.
    Ground screws are avaliable at hardware stores and big box stores. They are green in color. As far as I know any screw with that thread is OK to use as long as it is green.
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    The screw does not need to be green, but it does have to be a machine thread. Sheet metal and drywall type screws are NOT allowed.
    And yes, the box MUST be grounded first and foremost.
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    The Equipment Grounding Conductor, the box, and any device attached to the box must all be bonded together. In addition to the guidance Speedy Petey gave you, the screw used for gounding/bonding can be used "for no other purpose", so you can't use a Romex cable-clamp screw (but if you aren't using the clamp, throw it away and you can then use the screw for grounding). Somewhere else on this forum there's a nice cutaway picture showing a neat way to accomplish that: the ECG is wrapped around the screw in the box, and carries on to the screw on the device; neat, clean, with no wirenut cluttering up the works.
  6. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    Get some panel screws. They are easy to wrap around the wire around and continue it over to the ground terminal.
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    This isn't the best advice.
    There are about 10 different types of panel screws, and very few have actual machine threads.
    If you are going to go get anything, get real ground screws. I'd bet they are also ten times cheaper than panel screws as well.
  8. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Took the words right out of my fingers...
  9. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    VA
    Is this 12-2 with a ground or are you in an older house and want to run an equipment grounding conductor to each box?
Similar Threads: ground electrical
Electrical Forum discussion & Blog Electrical panel- no ground Feb 1, 2017
Electrical Forum discussion & Blog Grounding an older electrical box Dec 12, 2015
Electrical Forum discussion & Blog Water pipe used as electrical ground? Apr 26, 2008
Electrical Forum discussion & Blog Underground UF Wiring Gauge Selection Yesterday at 7:29 PM
Electrical Forum discussion & Blog Creating a new earth connection for grounding an outlet Sunday at 5:01 AM
