Grohmix Tub Shower Valve Problems
Discussion in 'Shower & Bathtub Forum & Blog' started by Charlie, Apr 3, 2005.
  1. Charlie
    Charlie New Member
    Apr 3, 2005
    After hours and hours of trying to reassmble my 20 year old fixture, I got it reassembled, but broke one of the two screws that attaches the push-pull mechanism to the valves.
    It's brass with a large head and has a hole through it. I found a screw that fits exactly but without the "hole" will I have trouble?
    Also,I now get no COLD water, maybe a trickle. I get hot water, could debris be causing this to the cold water?. This valve doesn't work regardless of which screw I use, with or without the hole.
    Do the valves need to be put in in a certain position?
  2. lambtron
    lambtron New Member
    Sep 23, 2006
    Oregon
    I suspect the hole is a pressure relief for the valve's inner plunger shaft. If this is the case then the replacement screw should also have a hole in it to prevent the stressful pressure difference that would otherwise develop when the shaft moves back and forth in the valve cylinder.
    Make sure the cold service stop is open. This service stops are located at the extreme left and right ends of the Grohmix. The service stop is fully open when its screwdriver slot is in the horizontal position.
    If this doesn't work then you may have a clogged filter on the cold stop valve. To resolve this you must remove the cold stop valve and clean the filter screen.
Similar Threads: Grohmix Shower
Shower & Bathtub Forum & Blog Grohmix shower no cold water Oct 18, 2012
Shower & Bathtub Forum & Blog blocked hot water inlet on grohmix 34 434 thermostatic shower mixer Jan 7, 2010
Shower & Bathtub Forum & Blog Grohe Grohmix stop valves Jul 8, 2014
Shower & Bathtub Forum & Blog Problem with Grohe Grohmix Thermo valve? Nov 16, 2011
Shower & Bathtub Forum & Blog Grohe grohmix cartridge 47 025 - missing trim and handle, how is it adjusted??? May 19, 2010
