Grohe shower drip -- please help!!!
Discussion in 'Shower & Bathtub Forum & Blog' started by zanadoo, May 5, 2006.
  1. zanadoo
    zanadoo New Member
    May 5, 2006
    I have a Grohetemp 3/4 inch mixer and 3 Grohe 3/4 volume controls (1 each for the body sprayers, fixed shower head and handheld). The shower drips constantly (mostly from the body sprayers, but the others drip a little too). I have replaced the cartridges in the volume controls because the plumbers I've spoken to all insist that this is the problem. Of course, the shower still drips like crazy. Here are my product numbers:
    Mixer: 34 902 -- http://www.grohecatalog.com/product/34902
    Volume controls: 29 268 -- http://www.grohecatalog.com/product/29268/
    I've spent tons of money on plumbers who can't seem to fix my drippy fixtures... any help would be greatly appreciated! Thanks!
  2. jadnashua
    Have you called Grohe?
  4. zanadoo
    zanadoo New Member
    May 5, 2006
    Absolutely! I've called Grohe several times... they too said that it was probably the volume control cartridges, and they even sent me new cartridges for free. But like I said, the problem is not the volume control cartridges.
  5. jadnashua
    How long do they drip? Unlike a tub with a shower valve, when you turn off a shower, there is no place for the water to go like it does in a tub...where if falls down and out the spout. The showerhead and arm will hold some water and drip for awhile, maybe hours before it empties enough to completely stop.
  6. zanadoo
    zanadoo New Member
    May 5, 2006
    Unfortunately, the fixtures drip forever. In fact, we ran a test: we have a cut-off in the utility room... I turned off the water to the shower entirely, opened all the valves and let the fixtures completely drain... after everything was bone dry, I turned the water back on in the utility room and the body sprayers begin dripping again (even though we never opened the valve to turn them on).
    All of the plumbers we've spoken to insist it's the cartridges in the volume control, but that clearly isn't the culprit. I'm just getting tired of paying plumbers to make an incorrect diagnosis!
    Thanks again for your help.
  7. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
    The volume controls are the only possible problem.
    You see, the thermostatic mixer is live all the time, only its outlet is controlled.
    The outlet is controlled by what? The volume control.
    You most likely have a problem with the seat, which sits further inside the valve body. (Look at #7 on the parts explosion)
  8. zanadoo
    zanadoo New Member
    May 5, 2006
    Problem solved
    You were correct... the problems were in the seats. The cartridges were working fine. In fact, a bunch of teflon tape around the threads in the seat did the trick.
    Thanks.
Similar Threads: Grohe shower
Shower & Bathtub Forum & Blog Grohe Shower handles? Oct 3, 2016
Shower & Bathtub Forum & Blog Help Identifying Grohe Shower Valve Mar 25, 2016
Shower & Bathtub Forum & Blog Hansgrohe shower head squeeling like a banshe Dec 11, 2015
Shower & Bathtub Forum & Blog Older Grohe shower fauct cap removal Nov 19, 2015
Shower & Bathtub Forum & Blog Need help with Toto vs Hansgrohe Shower fixtures Oct 6, 2015
