Grohe 33.939 europlus II kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ronnieray, Dec 16, 2012.
  1. ronnieray
    ronnieray New Member
    Nov 10, 2009
    Minnesota
    The water pressure on the hot water side of this faucet is down to a trickle. The cold water side pressure is normal. Anyone have an idea as to what the problem is? Links to instructions for performing the fix would also be helpful. Thanks in advance.
  2. jadnashua
    Many of the Grohe faucets have a bronze screen filter on the inlet water hoses...there could be some crud in there. Have you just tried the Grohe site? They at least have the parts list, if not the install/maintenance manual. I've e-mailed them before and they've sent me a pdf of the stuff I needed. It could also just be the shutoff at the wall - try removing the hose and run it into a bucket to see if that flow is good. Sometimes the washer in the shutoff breaks up and clogs things up.
  4. ronnieray
    Nov 10, 2009
    Minnesota
    Thanks, I will check it out in the morning. I will call Grohe as well to see what their TA guys say.
Similar Threads: Grohe 33939
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Grohe 3/4 roman tub diverter valve broke in middle removal help Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Grohe Roman Tub Valve Repair, 45346000 stems Oct 9, 2016
Plumbing Forum, Professional & DIY Advice Is a Grohe rough in box needed or just the PBV? Jul 6, 2016
Plumbing Forum, Professional & DIY Advice Trim Replacement for Grohe Classic Jun 28, 2016
