grinder pump clogging up
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rburt5, Jan 18, 2010.
  1. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    My father has a grinder sewage pump to get sewage from his basement up into his sewage tank. A garbage disposal, dishwasher, high efficiency washing machine, and a toilet (that doesn't get used very often) all drain through it. The basin for the grinding pump keeps getting plugged up with a thick, white, gooey substance that keeps the float from working. His plumber (who installed it) doesn't know why it's happening. He says he's never seen it happen before. Any ideas?
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    The gooey substance is more then likely grease. With the kitchen sink draining into it, it needs to be cleaned on a regular bases.
    John
  4. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    Thanks for the quick reply. I asked him about kitchen grease, and he doesn't think that's it. It's not a greasy kind of goo. It's chunky and gooey. He said it's almost the consistency of pie filling. I forgot in my original post that he also has a water softener that runs through it.
  5. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    That's what grease looks like after being in cold water.
    John
  6. sherriberri18
    sherriberri18 New Member
    Apr 12, 2011
    Victoria, BC
    Sewage Pump Clogging
    rburt5...did you have any success figuring out what was clogging the pump? We are having the exact same situation here, with the pump in the basement. Our tenants tell us that they aren't dumping grease down the drain, but what's clogging it is a thick, white, gooey substance. My husband thought it could be toilet paper or perhaps residue from powdered laundry detergent, but our plumber has no idea. This is the second time this has happened, and we're getting tired of rummaging around in our tenants' sh** tank, as you can imagine. Any thoughts/ideas/suggestions?
Similar Threads: grinder pump
Plumbing Forum, Professional & DIY Advice Questions about grinder pump for new construction Dec 15, 2015
Plumbing Forum, Professional & DIY Advice EONE DH071 Grinder Pump Problems Jun 28, 2015
Plumbing Forum, Professional & DIY Advice grinder pump system Aug 11, 2014
Plumbing Forum, Professional & DIY Advice grinder pump running often! Nov 25, 2013
Plumbing Forum, Professional & DIY Advice Newbie...Sewage grinder pump installation pipe help Jun 5, 2013
