Grinder pump alarm- how to troubleshoot
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Mplsmatt, Oct 18, 2012.
  1. Mplsmatt
    Mplsmatt New Member
    Oct 18, 2012
    MN
    Hello- we are staying a friend's cabin and the alarm on top of the circuit box for their grinder pump went off. I don't want to call the owner to bother them and I am trying to troubleshoot the alarm.
    The circuit box outside is a hydromatic but not sure of the actual pump specs. The documentation inside the box didn't provide any clue. I did cycle the circuit to see if I could reset the alarm but when I powered back on the alarm was still going. Looking online, it appears the alarm may be a high water level issue or perhaps a bad alarm switch but I cannot find any troubleshooting documentation online.
    Anyone have suggestions for how I should proceed? Thanks much!
  2. Mplsmatt
    Mplsmatt New Member
    Oct 18, 2012
    MN
    Also is there any danger to the pump itself if I leave it powered while I figure out how to troubleshoot? The "pump on" indicator light inside the circuit box is lit but I cannot hear the pump running. Just worried I will fry the pump if I don't cut the power. Thanks
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The alarm goes off because the liquid level inside the basin is too high. This could be because the pump or switch has failed. The only way to find the answer is to open up the basin.
    Unless you relish the thought of working in a sewage basin, you should probably check with the owner before getting in over your head.
Similar Threads: Grinder pump
Pumps and Tanks Well Forum & Blog Reliable replacement sewer pump grinder for eOne 2000 series? Mar 29, 2016
Pumps and Tanks Well Forum & Blog 600' Grinder pump system? Sep 25, 2015
Pumps and Tanks Well Forum & Blog Correct forum for info on submersible sewage pump with grinder? Mar 28, 2013
Pumps and Tanks Well Forum & Blog Issue possible grinder pump?? Feb 21, 2013
Pumps and Tanks Well Forum & Blog Grinder pump question Jan 12, 2012
