greenboard and hardiboard issues
Discussion in 'Shower & Bathtub Forum & Blog' started by Bob Affleck, Apr 23, 2006.
  1. Bob Affleck
    Bob Affleck New Member
    Apr 23, 2006
    I am remodeling my bathroom and I have installed hardibacker in the tub and shower areas and greenboard everywhere else. I have been told too many different things on how to finish the joint between the hardibacker and the greenboard. Do I use tape and joint compound or do I use fiberglass mesh and thinset?
    My next issue is: I am tileing on both the hardibacker and the greenboard. Do I have to use mastic on the greenboard and thinset on the hardibacker? My project is at a stand still until I find out. Thanks
  2. jimbo
    jimbo Plumber
    Best advice is to visit our friends at the tile forum, www.johnbridge.com They are really good.
    Just for discussion, I would offer that there is not necessarily one right answer. I would use mesh tape and waterproof joint compound. You may be able to use regular tape and joint compound. I would not use thinset.
    I believe that for areas not actually in the shower, you can use mastic or thinset on greenboard or hardibacker.
    That's my two cents. Check the forum I mentioned for more complete advice.
  4. jadnashua
    Thinset will work fine on the junction of the cbu and greenboard. If the seam will be entirely underneath the tile, treat it just like you would a cbu/cbu seam.
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    Vapor barrier behind the wet areas?
    Bob
    What waterproofing did you put behind the wet area? Better put a liquid membrane now if you have nothing yet. Redgard and Laticrete 9235 are known to be good.
    Thinset is a must in wet areas. Works well everywhere else too. Mastic is an optin in dry areas.
    David
Similar Threads: greenboard hardiboard
Shower & Bathtub Forum & Blog Drywall or greenboard above shower stall? Aug 8, 2011
Shower & Bathtub Forum & Blog Greenboard Okay For Tub Surround? Apr 5, 2011
Shower & Bathtub Forum & Blog Hardiebacker vs Greenboard Mar 16, 2010
Shower & Bathtub Forum & Blog Repairing old greenboard and drywall shower wall Jan 21, 2010
Shower & Bathtub Forum & Blog Tile over greenboard? Sep 12, 2006
