Grease Trap ST2- a gadget to remove grease trap from your kitchen
Discussion in 'Drain Cleaning' started by cherryrosh, Jan 20, 2014.
  1. cherryrosh
    cherryrosh New Member
    Jan 17, 2014
    Milton Keynes
    It is a plumbing gadget used to identify most of the greases because greases and fat oils are responsible for blockages in drain pipes.So, you can use Grease Trap ST2 to resolve your problem of interruption in the tube.It has 35 gallon capacity and will be effective for domestic kitchens.
    If you are fed up of getting clogging of the drains...Then, use this device and it has very easy installation and affordable also.
Similar Threads: Grease Trap
Drain Cleaning Grease Traps N.Ireland Mar 14, 2013
Drain Cleaning trap primer problem Mar 27, 2014
Drain Cleaning trapped snake head Oct 27, 2012
Drain Cleaning 1927 Main House Trap Clogged and Inaccessible Jan 24, 2012
Drain Cleaning Cleaning 4 inch trap, what to use? Mar 29, 2011
