grease trap? grease interceptor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tjbaudio, Aug 14, 2007.
  1. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    If I am on city water would I benafit from a grease trap? I have not had any problems with clogs so far but I know the wife is hard on the sink drain. I do see greas build up at the kitchen sink. We will be adding a garbage disposal and we have a dishwasher. I am also doing a compleat remodle and re plum of the house (see other thread)
    If I do put in a greas trap what do I have to do different to the pluming? How big do I go for 1 sink?
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Not for residentale plumbing.No need for a grease trap.Make sure your drains
    are in good condition you should have no problem.
  4. hj
    trap
    If you do install a grease trap and then a disposer, EVERYTHING you grind in the disposer will stay in the grease trap and you will have to empty it out periodically. You would have to empty the grease also, but ground up rotting vegetables make a particularly unpleasant job when you have to dipper them out.
  5. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Correct on both accounts.
    Grease traps are made for extreme amounts of grease, fat and food particles in commercial kitchens.
    They're one of the most unpleasant fixtures to work on due to the smell and content, there's no way around the maintenance...has to opened daily in some cases and cleaned out.
    They also take a considerable amount of space with the venting and drains.
  6. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    I used to alternate: work in restaurants for awhile, work in the trades for awhile... so I've smelled grease traps.
    The ones where they don't get it emptied, until it clogs up? Definitely make the short list of disgusting.
    You do NOT want a grease trap in your home. Really, you don't.
  7. tjbaudio
    Dec 6, 2005
    Wisconsin
    OK thanks guys. No greas trap it is!
  8. hj
    trap
    Try a 500 gallon grease trap at a Chinese restaurant. The trap was full of rice, right up to the manhole covers and all the way back up the line to the sink. This was within a few weeks of opening the store.
  9. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    I think of things like that when people think we charge too much.
    I can only begin to imagine what that must have smelled like.
  10. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    I'd installed one a few years back...immediately told the owner he was gonna have to put a strainer over the drain and make sure debris was thrown in the garbage not the drain.
    His old restrictor was a tiny "jukebox" shaped thing that effectively wasn't any good to trap grease...I knew he'd have to adjust to the new type with useage, maintenance and cleaning, especially with the flow restrictor.
    I showed him the flow restrictor and explained how to dislodge trapped particles by removing the lid.
    Next day he calls to tell me my drains failed and if I didn't get there right away he would hold me responsible for lost wages/business.
    I get there to find the restrictor completely blocked...potato peels sitting in the drain sump...made sure he stood there while I removed the lid and did exactly what I showed him how to do the day before...also grabbed a strainer sitting on the basins lip and put it in place in the drain sump.
    He reimbursed me for my time...I wouldn't have charged but for the fact that he'd insisted on the phone he had cleared the restrictor and done everything I told him to.
    I wouldn't even begin to consider one on a residence.
  11. hj
    trap
    Then there are the 3" flow controls that have an opening the size of a quarter in them, and they are inline so they cannot be cleaned if something larger gets into the line and plugs the opening.
    [​IMG]
  12. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Thats what I was referring to, but a 2" inlet...has a welded plate with a quarter sized restriction hole.
    When I install them I put a 2" drain connecting two seperate 1-1/2" traps with a 2" eco on the end so you can access it at least from the end opposite the interceptor.
    More expensive, but like you said, that thing is major trouble when something solid gets stuck there.
Similar Threads: grease trap
Plumbing Forum, Professional & DIY Advice Hello guys need some advice, bad smell from the grease trap room Feb 22, 2016
Plumbing Forum, Professional & DIY Advice Residential Grease Trap - Abandon in Place? Jun 30, 2015
Plumbing Forum, Professional & DIY Advice Septic tank/grease trap? Jun 7, 2013
Plumbing Forum, Professional & DIY Advice Grease Interceptor "Trap" Clean-Out Apr 12, 2013
Plumbing Forum, Professional & DIY Advice 3 compartment sink draining problem with grease trap Oct 13, 2010
