grean board and pink board
Discussion in 'Remodel Forum & Blog' started by lmei007, Mar 10, 2012.
  1. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
  2. jadnashua
    What's the R/inch? What's the price difference? What did they use to blow or create the bubbles? Is it an ozone reducing chemical? One brand may be just trying to make inroads verses the other if all of those things are equal. Could be as simple as how far away is the factory, or newer production techniques. Basically, I don't know, but a little research into the spec sheets should tell you. If space is critical, the greater R/inch may be worth the difference. Otherwise, it really doesn't matter...it's not like you're going to be looking at it...it must be covered up with a fire rated covering anyways.
  4. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    1.5lb XPS is pretty much the same, whether pink, green, blue or gray. SFAIK they all still use HFC143 or similar as the blowing agent. (not nearly as nasty as the standard blowing agents of 30 years ago, but non nearly as benign as the pentane used for blowing EPS.)
    Pactiv is one of the 3 largest manufacturers of XPS in north America, but more prone to OEMing it to house-brand names than big-blue/big-pink. I have no more issues with them as a manufacturer of XPS than anybody else. (They have a nice range of siding-underlayment products too.)
Similar Threads: grean board
Remodel Forum & Blog Looking For Something More Attractive And Durable That Standard Baseboard. May 1, 2016
Remodel Forum & Blog 15 minute thermal barrier at top of 2 inch xps foam boards. Oct 23, 2014
Remodel Forum & Blog Backer board for prefab shower Aug 28, 2014
Remodel Forum & Blog DUROCK Cement Board for Exterior Walls Dec 25, 2013
Remodel Forum & Blog insulation board under slate floor to warm it up Apr 25, 2013
