Gravity-Flow hot water recirc.
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by chucknewell, Feb 22, 2005.
  1. chucknewell
    chucknewell New Member
    14
    So. Cal.
    Recently did a kitchen remodel and while the walls were open I piped in a hot water recirculation system. It's 3/4" out of the water heater and into the attic. About half way to the kitchen it branches to the bathrooms (capped, not connected yet) and is reduced to 1/2" for the remaining 20' or so to the kitchen. It then loops under the sink, return on the bottom and is 1/2" line back to the water heater. All pipes are insulated. At the water heater is a Grundfos circulator and flo-check valve (horizontal install) just before the line enters the tank at the bottom drain port (tee'd). It all works fine except it seems to be circulating on its own. The hot water out pipe is always hot and the return line is always warm. I've tested the circulator but waven't wired it up yet so it can't be kicking on. Do I need to bring the hot water out line below the drain level to stop the gravity flow? :confused:
    Chuck
  2. Gary Swart
    Gary Swart In the Trades
    7,329
    Yakima WA
    I could be wrong, but I think you're system is normal. I have a different brand recirculating system and while I've never have check it when it was not plugged in, I think it would circulation some without the pump. You could check with the manufacturer, they probably have a website with a phone number for their tech department.
  3. chucknewell
    14
    So. Cal.
    Manufacturer. . .
    Gary,
    Thanks for your input, I appreciate the reply. Unfortunately this is a "home brew" system. Since I designed it I'll have to fix it. I know I could put a solenoid valve on the return line to stop the flow, but I'd rather do it passively to keep the system simple.
    Thanks again
    Chuck
  4. hj
    26,488
    circulation
    If it is circulating by convection, what is the problem. It would be more of a problem if you wanted it to circulate and it didn't, which would be the normal situation since a convection system has to be installed to very precise parameters.
  5. chucknewell
    14
    So. Cal.
    It's not supposed to be a gravity flow system. I'm in San Diego where energy costs are quite high and I don't want the water heater to cycle unnecessarily. Also, the controls for the pump are three parts: Timer, Open on temperature rise t-stat, and a close on temperature rise t-stat. The timer and open on rise t-stat function as usual. Clock turns on pump, hot water gets to kitchen t-stat opens - pump turns off. The close on rise t-stat is the other reason I need to stop the free flow. The idea is to be able to "turn on" the recirculation system remotely during times when the time clock doesn't have it on. The close on rise t-stat is on the hot water pipe a couple feet from the water heater. So, any hot water faucet in the house becomes a switch to activate the recirculation system. Turn on a hot water faucet for a couple of seconds, the pipe at the water heater fills with hot water, closes the t-stat, pump comes on and sends hot water to all faucets.
    I know this seems like a lot. Mostly it's to save water; my last water bill was $234 for two people living in a 920 sq. ft. house. I hate running water down the drain while waiting for it to get hot.
    Chuck
  6. Clayton
    Clayton Plumber
    124
    To circulate or not to circulate
    install heat-trap nipples
  7. chucknewell
    14
    So. Cal.
    Nipples are already installed. Thanks any way. I broke down and bought a solenoid valve today. Job done.
    Chuck
Similar Threads: Gravity-Flow water
Plumbing Forum, Professional & DIY Advice, Tips & How do I plumb a primitive gravity-flow water system? Apr 18, 2005
Plumbing Forum, Professional & DIY Advice, Tips & vacant house, water off or on Today at 6:55 PM
Plumbing Forum, Professional & DIY Advice, Tips & Reliance 606 water heater keeps shutting off Yesterday at 4:30 PM
Plumbing Forum, Professional & DIY Advice, Tips & hot water heaters need to decommission chimney Wednesday at 9:04 AM
Plumbing Forum, Professional & DIY Advice, Tips & gutter lip missing, water coming down between wall and gutter Monday at 1:58 PM
