1booches
I have a gravity fed water system fed from a spring and into a 1000 gallon holding tank about a 100 feet elevated from my house, pressure an sediment are my two problems... I have installed a 50 gallon drum with a in and out up high and a clean out valve at the bottom before my holding tank to try and relieve the sediment problem..
Now my question is: installing another holding tank with a pump, bladder, filters and a uv system.. Is that something I should do to help my issues?
Oh yes, 1" line from the spring to the tank.
1" line from the tank to a valve and 3/4 to the house about 30 feet away.
