Granite Countertop for a vessel bowl
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by CHOSEN, Dec 16, 2012.
  1. CHOSEN
    CHOSEN New Member
    Dec 16, 2012
    Washington, DC
    I just received my special order countertop, for my vessel bowl, from LOWES. I notice that the hole that was drilled for the drain, is not located at the center of the countertop. The hole is in the center as far as the x-axis (left to right) is concerned, but the y-axis (from the wall, to where I'd be standing), is off by at least 2". The hole is closer to where I'm standing. I put the vessel bowl on the countertop, and I notice that the edge of the bowl, is about 1" from the edge of the countertop. Is that normal, or should I bring the countertop back to LOWES? Please advise.
  2. jadnashua
    You normally need some extra room behind the bowl for the faucet, whether it is in the counter or coming out of the wall, so it may be offset towards the user a bit.
  4. hj
    The opening for the drain depends on the size of the sink AND where you want to locate it. There is no "generic" location, so either you bought a sink and top combination, or someone must have told Lowe's where to put it. As mentioned, there has to be provision for the faucet whether at the back on to the side, unless you have a wall mounted faucet, in which case, that also affects the sink location.
Similar Threads: Granite Countertop
Plumbing Forum, Professional & DIY Advice Sink fitting in new granite countertop question Oct 18, 2012
Plumbing Forum, Professional & DIY Advice Attach SS Sink to new Granite Countertop Apr 12, 2011
Plumbing Forum, Professional & DIY Advice Dishwasher under Granite countertop Jun 27, 2009
Plumbing Forum, Professional & DIY Advice Removing/Replacing Sink from Granite Countertop/Vanity Top Mar 25, 2009
Plumbing Forum, Professional & DIY Advice Granite Countertop Installs Dec 20, 2006
