Grab Bars
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Nov 16, 2010.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    OT: but for those that have purchase grab bars, what sites/places have you purchased them.
    Just looking for feedback as there is quite a but of places that sell them - whether it be online or local.
    FWIW, I'll be using Wingits...so a compatible system would be great.
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    Grab bars can be slider bars for handshowers, if they are made for this. Moen and Jaclo have this. That is what I have learned from web searching. I haven't seen them. I wish I had known this a few years ago. It would have resolved a dilemma at home, where one important person didn't want grab bars, since they're "too ugly for words."
  4. jimbo
    jimbo Plumber
  5. jadnashua
    I've found that the screw pattern on the Wing-It safety bar fastener will fit many other brands. The thing that can be the biggest hassle, regardless of whose you use, is that there is not very much slop in installing the things. I used some in my mother's shower install and they worked great. Much cheaper to just screw into blocking, but if you don't have it, they are a great item. Depending on the bar's mounting flange, you may only have 1/16-1/8" slop in drilling the mounting holes. I suggest making a jig with the holes the proper distance apart and then using it to guide your core drill bit to make the holes rather than trying to measure and drill free-hand through the tile. A drill press to get the holes perfectly perpendicular through your jig is also a very good idea, but if it isn't very thick, it won't affect the distance.
  6. Hairyhosebib
    Hairyhosebib New Member
    Jun 23, 2010
    Arizona
    I bought one at Home Depot. They have different lengths
  7. jadnashua
    What I was trying to say is that if you are going to use Wing-Its, when you drill the hole in the wall to mount them, your tolerance is VERY small, or the holes in the bar itself will not line up to mount the bar to the Wing-It. So, to save yourself trouble, it will probably be easier to make a template, drill some holes, make sure the bar will fit into the template, then use the template to make the holes in the wall. I think the Wing-its are a good answer for an added on safety bar...they are well made, solid and if your wall meets the specs, should easily meet the proper strength. Because of the cost, I would not use them if I could or had installed blocking so I could simply use screws.
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    You might also try what they call "assist bars".
    A grab bar improperly fastened might equal an assist bar properly fastened. The weight and age/strength of the user also counts.
  9. jadnashua
    A pair of Wing-Its are spec'ed to meet ADA requirements for a safety bar...if you haven't seen one, the coller is almost the size of the mounting flange of a bar, fits in a large hole with a sleeve, and has somewhere around 8 strong SS fingers that spread out in about a 3-4" circle behind the wall that gets compressed against the back. Once installed, it isn't going anywhere.
  10. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    LED Grab Bars by "elio"
    Grab Bar placements - Following ADA guidelines
    [​IMG]
    The ADA guidelines are way out dated and this was a common theme at the Health Care Design Conference this past week.
    Review carefully the placement and insure you have the horizontal grab bars in place. Most frail persons will not do well grabbing a vertical grab bar. Careful what is advised by your builder, setter or General Contractor.
    There was a research study presented in Las Vegas that showcased how out dated these ADA guidelines are. The ADA guidelines adapted to help "Fit - Strong - Men" "Soldiers" not "Grannies"...
    [​IMG]
    For more information contact;
    Bob Van Driel
    Manager, Industrial Products Group
    elio a Division of ITC Inc.
    230 E. Lakewood Blvd
    Holland, MI 49422-8338
    t. (616) 403-8957
    e. robertv@itc-us.com
    Here is a look at a great new option for seniors with partial vision related issues.
    http://www.elio-itc.com/product/illuminated-safety-handle
    Illuminated Safety Handle
    I have been reading a great book by Jacob Liberman, O.D., Ph.D. titled "Light - Medicine of the future" in the book the history and the healing properties of light are discussed. Blue light is especially good for the body and studies have shown it's help with treating diseses since 1876 (General Augustus J. Pleasanton)...
    I'll post some more detailed pictures and installation advice once I get one of these LED bars in my shop.
    JW
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Product testing
    It's time to light this puppy up!
    I received my Elio Grab Bar the other day and me and the boys are going to light it up.
    Can't wait.
  12. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    It's powered up...
    Looks Fantastic!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  13. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Don't they look great! I'm waiting on a new version and some different colours but these are fantastic.
    I'll see how they look when dimmed...
  14. jimbo
    jimbo Plumber
    Oh great! Electricity in the shower...I can hardly wait!
    BTW...this is an interesting discussion about whether the ADA is out of date. But just fail to comply with an ADA spec, and that famous "gotcha" lawfirm , Dewey, Cheatham, and Howe, will own your business! Happens all the time down here. So little mom and pop restauraunt, they go in with calipers and find the stall is narrow by 1/2" or the lav mirror isn't tilted enough....GOTCHA!
  15. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Senior Safety at Night - LED Grab Bars ( Margaret P. Calkins, PhD, CAPS, EDAC )
    LED Grab Bars it seems have caught the eye of Margaret P. Calkins, PhD, CAPS, EDAC and for those of you who have not had the pleasure to meet her she is a wonderful resource of information into patient care and Universal Design. I meet Margret last year at the Health Care design conference and look forward to her looming research paper on LED lighting and the improvements in patient safety in our hospitals.
    [​IMG]
    LIGHTED GRAB BARS
    One of the most interesting products to recently appear is the lighted grab bar. It is well documented that most falls occur at night, as residents get up to go to the bathroom. When a light is turned on at night, the sudden change of light levels can be physically painful, and the contraction of the pupil is not immediate. If the bathroom light is on, then turning it off before heading back to bed can cause momentary blindness. Both situations put people at high risk for falling. A lighted grab bar provides enough light to find the toilet without having to turn on additional lighting. It also highlights the bar so it is easier to see and use."
    - Margaret P. Calkins, PhD, CAPS, EDAC * SOURCE
    This new research to my understanding is taking place both here in North America and abroad.
    In the current issue of Long Term Living (March 2011) Margret includes "Lighted Grab Bars" as on of the most interesting products to appear and lists them in her Top Senior Living Design Innovations article.
    Here is a link to the article if you would like to read the whole thing;
    http://www.nursinghomesmagazine.com...d=&tier=4&id=88DB100C3E02433CA8DE29E35006607E
    If you would like to contact Margaret here is her info;
    Margaret P. Calkins, PhD, CAPS, EDAC, is President of I.D.E.A.S., Inc., and Board Chair of IDEAS Institute. She currently serves on the Boards for Pioneer Network, and the American Society on Aging. Contact her at MCalkins@IDEASConsultingInc.com.
    Margaret has many great published article and books for download at her site.
    * SOURCE
  16. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    A long wait is over.
    I just received my first two grab bars from Elio and the quality and new design is outstanding. I'm post a few new pictures of these LED grab bars once I hook up the power supply.
    Night Lighting and Grab Bar choices just got easier.
    JW
  17. chefwong
    chefwong Member
    Jun 14, 2006
    The grab-bars for the OP was for a relative of mine - who fell and since that fall, has been impaired from waist below.
    I ended up doing full grab bars, tub bench retrofit and a couple of other assist mods.
    Not a fan of the led grab bars......
    I do think the LED lights in the P&S GFCI outlets looks great and work somewhat for ambient lighting.
    Call me old school. I still prefer halogens and incadescents. I still prefer the coloration
  18. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    ELIO Led Grab Bars and barrier free bathrooms
    Chef Wong there are studies being done into the success of these LED Grab Bars in hospital studies. I believe the Doctor researching the subject is Dr. Margaret P. Calkins (http://www.ideasconsultinginc.com/pages/StaffBios.asp) and I had the pleasure of listening to her speak on the subject of paitent safety and vision related falls.
    Another White Paper study in Spain has shown that these safety improvements help patients navigate from bed to toilet and the soft light is easy and not blinding on the eyes.
    The waterproofing measures are simple ones and the design of the mounting hardware allows a through hole to be drilled away from the mounting screws. I would think some Kerdi Fix would do the job perfectly.
    My father in Law as we speak is in Lions Gate hospital - the result of a fall and not being helped for almost 3 hours. He did not fall in the shower and he did not trip over anything. His fall the result of reaching out for support and grabbing his rolling chair - not the best plan.
    Any improvement in safety is welcome in my books.
    I will be offering these LED grab bars to my clients and installing them for those in need. Even if the bar is not hardwired they look great and are wonderful to touch. I find stainless steel hammered metal to be an institutional look and one I do not care for. Many medications can affect a persons vision and in the early morning hours and nightlight of any kind can improve the ease of finding the toilet in the dark.
    Night lights and such should be in my opinion wired to a timer or photocell switch. My father in law has enough to remember just taking is pills at the right time of day - running around at night switching on night lights I'm sure not one of his priorities - but it should be.
    [​IMG]
    A few of these ELIO LED Grab Bars would have looked great in this barrier free shower we wrapped up last year. My client offered up the stool for my father in law and when I stopped by I snapped a few pictures of the equipment I purchased. Building a bathroom as a barrier free design open the doors to many more years of enjoyment. This bathroom has no tripping hazzards and offers up the safety of a one way slope.
  19. oldanbo
    oldanbo New Member
    May 30, 2006
    Sequim,WA
    Where are the bars in this pic??? I don't see any. (I know, that's the point, right?) :cool:
    Can you point me to them, please?
    Thank you
  20. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Whoops. The shower above has no grab bars and is showcasing nothing more than a one way slope and barrier free design.
    The Grab Bars I'm talking about look like this.
    [​IMG]
    The install process is shown here - http://www.facebook.com/media/set/?set=a.101126403346257.1441.101109810014583&type=3
    JW
  21. chefwong
    chefwong Member
    Jun 14, 2006
    Great looking build nontheless JW ! Good job.
    Kinda odd to see assist items but no grab bars
    Humor me. On the right side inside the shower, that white wall....what is the composition of whatever is there ?
    Hard to pick up the pics.....just looking for inspiration always
Similar Threads: Grab Bars
Plumbing Forum, Professional & DIY Advice Granite Grabbers or screws to side for Dishwasher mount? Jan 20, 2016
Plumbing Forum, Professional & DIY Advice ADA bath faucet as grab bar Mar 11, 2013
Plumbing Forum, Professional & DIY Advice Need Advice on preventing drilling into Water Lines - Grab Bar Installation... Aug 29, 2010
Plumbing Forum, Professional & DIY Advice Grab bar in fiberglass shower Jan 14, 2009
Plumbing Forum, Professional & DIY Advice Need to remove drain baskedt that crossbars are broken off Apr 18, 2010
