Gould pump keeps running
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Templass, Aug 22, 2009.
Thread Status:
Not open for further replies.
  1. Templass
    Templass New Member
    Jun 16, 2008
    Well, I'm back ... same problem different year, and I'm going crazy.
    We have a 280' deep well with a 3/4 hp Gould pump, in the basement. The pump shuts off, but only after it runs for 1/2 hr or so. We lowered the switch setting to 17-37 because it seemed to take forever to go beyond the 37 psi level. Needless to say, our pressure sucks.
    When we run the outside hose with the water wide open it loses pressure after a while and water slows to almost a trickle.
    Do we need a new pump ... new well (nooooooooo)?
    I know nothing about the insides of the pump, but I'll tackle anything (as long as it's explained sorta like a Dummies for Pump parts book).
    Thanks guys, ahead of time, because I LOVE this website. I tell everyone about it.
    Regards,
    Jackie:
  2. jadnashua
    If you look at your private messages, you'll see I moved your original thread where it is likely to get more help.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    1 - Pump is going bad, (impellers & or motor)
    2 - Well is going bad (no water, no recovery)
    3 - Pump screen is plugged ( sediment )
    4 - Pretty bad leak in the line ( may be at the pitless gasket )
    All 4 require the pump coming up out of the hole.
Similar Threads: Gould pump
Plumbing Forum, Professional & DIY Advice Well pumps Sunday at 9:39 AM
Plumbing Forum, Professional & DIY Advice Septic system-- to what degree do I try to avoid a pump in the system? Friday at 10:59 AM
Plumbing Forum, Professional & DIY Advice Need help with Pump Pressure switch shutoff Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Hunter Pump Start Relay 22 Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Heat Pump Mar 13, 2017
Thread Status:
