gould pump and pressure switch
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jim.weatherup, Feb 7, 2005.
  1. jim.weatherup
    jim.weatherup New Member
    Feb 7, 2005
    I am having some problems with my pump and pressure switch. It was drawing air, I replaced my footvalve and that problem cleared. Things went well for a while, then it wouldn't go any higher on the gauge than 23 lbs, pump ran continuously. I have been told not to go above 20 pounds as a low start, why is this? If I had the pump start at 35-40 and high limits at 55 or so, the pump may run more times but would run shorter times.
    Also, when I loosened the tube to the pressure switch until water came out, did this a couple times, got the pressure up. So I assume that there is some debris that got loose during my first problem. So I guess my question is the easiest way to clean that tube and readjust my switch? There is no cover on the pressure switch, so I am not sure which is high and low. It appears to be square d , is a 1/2 horse 110 volt ao smith goulds pump.
    Didn't mention that this is on a driven well point, about 25', 3/4" plastic inside a 1 1/4" pipe. Pump seems to run too long between high/low, about 4 minutes. Never runs out of water, doesn't pump dirt.
Similar Threads: gould pump
Pumps and Tanks Well Forum & Blog. Water is life. Goulds GS or Sta-Rite HS Pumps? Mar 5, 2017
Pumps and Tanks Well Forum & Blog. Water is life. How to repair Goulds deep-well pump Sep 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Goulds Balanced flow constant pressure pump May 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Goulds j5 pump with shallow adapter May 16, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Re-assembling A Submersible 1/2 Hp Gould Pump Motor May 2, 2016
