Gould jet pump humming tripping breaker
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Casey56, Aug 6, 2010.
  1. Casey56
    Casey56 New Member
    Aug 5, 2010
    Lake Wales, Fl
    I have a Gould j10s 1Hp that just keeps humming and tripping the breaker. I had a leak the night before and replaced some of the piping but the pump won't run. I replaced the pressure switch and took hte back off the pump to see if it turned easy and it does, but neither helped the humming or breaker issue. Can someone please help I just lost my job a few weeks ago and am having major medical issues so if I can fix it myself it would be great Thanks
  2. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    9/10 times, humming pump means burnt up motor. If it does spin freely, u could try a new capacitor but most likely you will need a new motor.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    You can find some cheap ACE pumps on the big auction site, usually "refurbished" meaning returns to Lowes
  5. justwater
    May 13, 2010
    FL/GA
    i would hate to see you replace that j10 with a cheap hardware pump. before i did that, i would buy a new motor from the hardware somewhere and install it on the j10. those are good pumps.
  6. ballvalve
    Dec 28, 2009
    If he has no money and medical issues, an ACE or FLOTEC pump might keep him in water for years. I doubt he has the abilities to swap the motor. If he does, they [motors] are all about the same level of bad, so he could buy the cheap pump for the motor and toss the pump head. I have bought Flotec submersibles with new franklin motors [one level of good] just to get the motor - much less than a new motor from any store.
  7. justwater
    May 13, 2010
    FL/GA
    neither flotec or water ace motors will swap to a j10. i just know what a good pump that goulds is, hate to see it replaced by one of those cheap pos pumps. i guess you gotta do what you can afford and do yourself though, so good luck with it all.
  8. ballvalve
    Dec 28, 2009
    I have replaced many pump motors, trying to save some old iron. Beware of the frame # with a 'sp' at the end. 'special' ; [we made a special effort to screw you!] it means they used a special parameter and the shaft [with motor attached of course] will be custom and will only come from their parts house - usually 275$ for a 250$ pump.
  9. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Before I purchased a pump or motor I'd check the starting switch in the rear to see if it's burnt or stuck in the running position. If it appears ok I would replace the capacitor. Burn't out motors usually smell burnt.
  10. ballvalve
    Dec 28, 2009
    He probably fixed it already but good point. I have some booster pumps that throw off their springs on the start switch at regular intervals.
Similar Threads: Gould pump
Pumps and Tanks Well Forum & Blog. Water is life. Goulds GS or Sta-Rite HS Pumps? Mar 5, 2017
Pumps and Tanks Well Forum & Blog. Water is life. How to repair Goulds deep-well pump Sep 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Goulds Balanced flow constant pressure pump May 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Goulds j5 pump with shallow adapter May 16, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Re-assembling A Submersible 1/2 Hp Gould Pump Motor May 2, 2016
