Gould J10S w/ Cracked Cast Iron Parts and Other Problems
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by BillyJoeJimBob, Oct 30, 2013.
  1. BillyJoeJimBob
    BillyJoeJimBob New Member
    Jul 18, 2011
    San Antonio, Texas
    The motor works just fine.
    1) The Casing (1K333) is cracked where the pump was not drained properly and water froze inside, and then some time before I acquired it, the crack was welded badly. I've ground-down the bad weld to fully-expose the crack, in preparation for getting it welded again.
    2) I broke one of the dog-ears off the Motor Adapter (K310) by over-tightening it. I think it can be welded & repaired.
    3) I broke the Impeller (2K61) by tapping it with a rubber mallet, trying to loosen it from the shaft.
    3) Finally the Diaphragm (5K162) is stiff, rusty, ragged and looks like it needs to be replaced.
    I've made a few phone calls and have been told that you cannot by just the pump assembly; you can only buy the (expensive) parts one at a time. I've looked online and it appears the pump is the "weakest link" as I find no one selling a broken J10S with a bad motor & good pump.
    I'd like to rebuild the pump and put it into service as a booster pump, with a adequately performing Grundfos MQ, or failing that, either do "something" with the motor, or sell it. But I cannot find a market for these motors, even though they seem to be high-quality. Can I buy a non-Gould pump and use this motor with it? I have this working, seemingly high-quality motor and am looking for a way to avoid throwing it away. Any help?
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Welding cast iron is generally a pathway to failure. Why not keep the motor as a spare for a new J series pump?
  4. BillyJoeJimBob
    Jul 18, 2011
    San Antonio, Texas
    Is it cast iron? I just assumed it was because it was bumpy. The previous weld might have worked if it hadn't been 1/8" off the crack, lol...
    If I were to buy another pump, I would want something heavier-duty? Besides that, I don't see the motor likely to go bad. I've had this thing laying around for a couple of years and it's time to do something with it.
  5. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Any cast iron pump that has water freezing in it will die an early death, and heavy duty don't enter into it. The Goulds J+ series jet pumps are top quality items.
    All that said, the motor is a standard pump motor with a 56J frame, so maybe you can find a burned-out pump to match it up with.
  6. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    like wetboots said, J10 is top of the line but nothing cast iron and full of water is gonna stand up to a freeze. did you call around to any drillers/installers to see what they had laying around? i know ive got a couple used pump ends for that motor, good chance some others closer to you do too... for cash no doubt. good luck
  7. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I have always had better luck with brazing on cast iron.
  8. Wet_Boots
    Mar 23, 2007
    Metro NYC
    ...and the nice thing about a good used pump end from a dealer, is that the impeller has already been safely removed, so no rubber mallet required...
  9. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    A competent welder using nickel rod can fix that, but it may distort from the heat.
  10. Wet_Boots
    Mar 23, 2007
    Metro NYC
    I'd still think the money would be better utilized on a used pump end, or a local bargain on a lightning victim pump.
  11. craigpump
    Apr 12, 2012
    No argument there, I wouldn't waste my time on it either.
  12. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Cast Iron can be repaired, If done properly.
    The key is to heat the complete piece up, before attempting to repair the bad area.
    Some Backward Welders use a gas Grill to preheat the work piece.
    Next time you should consider using a Torque wrench, and make sure everything is lined up properly.
    May be best to buy another, I would not trust that one unless I used JB Waterweld. LOL
    Good Luck.
  13. BillyJoeJimBob
    Jul 18, 2011
    San Antonio, Texas
    The JB Weld. Was that a joke? Because I'm thinking about trying it.
Similar Threads: Gould J10S
Pumps and Tanks Well Forum & Blog. Water is life. Goulds J10S Humming Mar 14, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Replacing a Goulds J10S 1 hp pump for home sprinkler system Jul 6, 2010
Pumps and Tanks Well Forum & Blog. Water is life. repair a gould j10s Jun 21, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Help - Gould J10s Jun 21, 2006
Pumps and Tanks Well Forum & Blog. Water is life. How to repair Goulds deep-well pump Sep 24, 2016
