Gould BF03S pump with bladder tank
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by cmose40, Dec 30, 2012.
  1. cmose40
    cmose40 New Member
    Dec 30, 2012
    Boston MA
    Our lakeside summer camp has a 40 +/- year old Gould BF03S pump, pumping from the lake. The BF03S is a non-submersed shallow well pump with a float Type air volume control. Within the last few years a Sears 19 gal captive air bladder tank was added to the system. Operationally there are no problems, we have good water pressure and the pump cycles fine.
    This winter I have rebuilt the BF03S. I have noticed a small leak in the diaphragm of the air volume control. This is a float type AVC, which operates a an air bleeder valve to activate a second valve to inject air on the suction side of the pump. Anyway, given there is a bladder tank in the system, do I even need the AVC on the pump? I am wondering if I do need to replace it, or can I just cap it off and go without it. Not sure if the AVC is needed for anything if there is also a bladder tank. But also, "if it ain't broke" applies, as the pump seems to work great with AVC and bladder tank.
    Thank you.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I would think that if the air snifter was working, you would be getting air in your lines. With a bladder tank, there is no where for the air to go except out the faucets.
  4. cmose40
    cmose40 New Member
    Dec 30, 2012
    Boston MA
    Yes I suppose it is very possible that the AVC has not been functional at all. But should I go ahead and remove it, or is it worthwhile to restore its function.
  5. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    That big bulb on top of that pump is a regular hydro pneumatic (non bladder) type tank. It needed air to work properly. But since you added a bladder tank you don't want to add any air to the system and just let the bulb tank get waterlogged. So I would remove the air injector so it can't work.
    [​IMG]
  6. cmose40
    cmose40 New Member
    Dec 30, 2012
    Boston MA
    Thank you for the replies, that's what I needed to know. Great forum here.
Similar Threads: Gould BF03S
Pumps and Tanks Well Forum & Blog. Water is life. Gould BF03S pump May 5, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Help with Gould Balanced Flow Pump (BF03S) Feb 14, 2010
Pumps and Tanks Well Forum & Blog. Water is life. How to repair Goulds deep-well pump Sep 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Goulds shallow well adapter May 22, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Goulds Balanced flow constant pressure pump May 20, 2016
