Got my toilet back in service, thanks Terry & Jim...
Discussion in 'Toilet Forum discussions' started by tom-rad, Apr 6, 2010.
  1. tom-rad
    tom-rad Member
    Sep 2, 2007
    Maryland
    You guys know plumbing. Every bit of advice I found here was correct.
    The reason for the leak was the toilet was sitting on the flange, and I had used a 'No Seep' ring with the plastic insert. I did as your site recommended, used a regular wax ring, put it on the flange, set the toilet on it, all was well.
    I made a shim plate out of 1/4" plywood, with sheet vinyl top & bottom. Planning to get a piece of marble or Corian later on, but this works fine. The bottom of the toilet sits on the floor, not on the flange.
    Again, thank you for the advice.
    Tom:D
Similar Threads: toilet service
Toilet Forum discussions Minimum height of shelf above toilet tank cover for ease of service Aug 27, 2016
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Saturday at 9:53 AM
Toilet Forum discussions Icera wall-hung toilet Saturday at 8:36 AM
Toilet Forum discussions Toto toilet seat hinge cover Friday at 4:53 PM
Toilet Forum discussions Toilet Flange not Flat/Level Tuesday at 2:21 PM
