good quality shower valves for low pressure system
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bigwooo, Nov 15, 2010.
  1. bigwooo
    bigwooo New Member
    Sep 3, 2009
    Retired Firefighter
    BCS Mexico
    I'm in the process of building an off grid home in Mexico. My system relies on a 12 volt pump, pumping out of an underground storage tank to a pressure tank. My pressure switch will be set a 30-50 psi, meaning when the pressure drops to 30 psi, the pump will turn on and fill the pressure tank until it reaches 50psi. I cannot provide more than 50 psi with a 12v pump.
    My plumbing will be 1/2" PEX on a "home run" system.
    I'm looking for suggestions for high quality shower valves that don't cause an appreciable decrease in pressure. I've had experience with some "water saver" valves that don't work well at all in the pressures I've described. If possible, I would like to buy old fashoned basic hot and cold adjustable valves without pressure balancing, temp adjusting etc., if they are still available somewhere.
    Any suggestions would be greatly appreciated.
    Thanks.
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    The water saver is in the shower head not the valve, most new valves are pressure balancing but I have seen some old style still available in some stores and they state on them not for use in new contruction.
    Mexico code could be different.
  4. bigwooo
    bigwooo New Member
    Sep 3, 2009
    Retired Firefighter
    BCS Mexico
    Ahhh... thank you, you're correct. I remember now, it was the shower head...not the valve that caused the pressure issues I had a while back; but...I don't have experience with the pressure balancing valves on lower pressure. I don't have a problem installing one if I can determine it will work OK.
    Most people around here buy the cheap old style valves available locally, but they don't last. I'd like to purchase something that's not going to have to be replaced in 6 months. Does anyone know if pressure balancing valves cause a significant drop in pressure? Any brand preferences. BTW, I had to laugh...Mexico has no codes :)
  5. Terry
    Aug 17, 2004
    If you have 30 PSI, then any of the Delta, Moen, Grohe and Kohler will work for you.
    You can get parts for these, and the quality is good.
    That's at the low end, but it works.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Many many people on well systems have 30-50 psi pressure switches and have no complaints.
    In Mexico I'd be more concerned that the plumber Installed a trap on the tub/shower than the valve.
  7. hj
    A pressure balancing valve will only cause a DROP in pressure, if the hot or cold pressure drops and then the PB will balance the other one to the same pressure, which will be seen as a pressure drop. Without the PB valve, that same effect will cause a surge of hot to cold water in the shower.
  8. bigwooo
    bigwooo New Member
    Sep 3, 2009
    Retired Firefighter
    BCS Mexico
    Thank you for all the information. Right now I have a 20/40 pressure switch, but just ordered a 30/50 that I'll be picking up on a trip North. (20/40 is all that's available in Mexico). It looks like I have a good choice of valves for that pressure.
    Muchas Gracias.
  9. bigwooo
    bigwooo New Member
    Sep 3, 2009
    Retired Firefighter
    BCS Mexico
    You are soooooo correct. My guest house doesn't have any. Unfortunately I wasn't here to supervise. Now that I live here "things will be different".
Similar Threads: quality shower
Plumbing Forum, Professional & DIY Advice Quality multi-function handheld showerhead with pause function Apr 11, 2014
Plumbing Forum, Professional & DIY Advice Is there a quality shower base out there that does not cost $1700.00? Jan 27, 2012
Plumbing Forum, Professional & DIY Advice Good quality 3 handle tub/shower valve Jun 24, 2011
Plumbing Forum, Professional & DIY Advice High quality shower valve Sep 6, 2010
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
