Good quality 3 valve faucet (tub) thats easy to repair?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by AcidWater, Nov 6, 2012.
  1. AcidWater
    AcidWater Member
    Oct 14, 2008
    Need to replace an Eljer. Standard 8" spacing. Want a brand that has a bibb seat which can be removed without hassle, and that I can get parts for easily. I'm told the Eljer might have been installed without being sweated in place; so I might have an easy time installing the new one. Have to cut open the wall to find out...
  2. jadnashua
    There are very few of those left since they don't meet current code (which requires anti-scald technology). Depending on your local inspector, replacement often would require bringing things up to code, and this isn't. While there are some anti-scald add-ons that could be plumbed into it, it becomes a bit more complex, and it's cheaper to just use something that does meet code out of the box.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Best one...of the very few still made....is Price Pfister. ( Actually known today as Pfister Faucets). It is still available as compression function ( with bibb washer and seats) but a better choice is the ceramic stem version. They use the same trim. Your choice of trims will be limited...dont look for venetian bronze! but parts will be available for your lifetime!
    I can't say for sure that the union on your eljer will match up. Most likely you will have one union piece soldered to the pipe ( unless your plumbing is galv.) so you can unsweat that and replace with the new one if needed.
  5. AcidWater
    AcidWater Member
    Oct 14, 2008
    Access to tub faucet - size of hole in drywall?
    How big a hole do I need to cut behind the tub faucet to replace it? Want plenty of working room. The valves are 24" above the floor, the spout about 19". 3 valve type with 8" spacing. Its in a closet so I can go large... stud indicator says there's a stud in the middle...
  6. AcidWater
    AcidWater Member
    Oct 14, 2008
    Something funky with the editor -- the big question is
    How much above & below that should I allow to get to the unions, if present?
  7. AcidWater
    AcidWater Member
    Oct 14, 2008
  8. hj
    Pfister 01-111,
    01-311,
    01-321
    and several others up to 01--912 depending on the features and handles you want.
Similar Threads: quality valve
Plumbing Forum, Professional & DIY Advice Quality PEX valve? Dec 21, 2015
Plumbing Forum, Professional & DIY Advice Good quality 3 handle tub/shower valve Jun 24, 2011
Plumbing Forum, Professional & DIY Advice good quality shower valves for low pressure system Nov 15, 2010
Plumbing Forum, Professional & DIY Advice High quality shower valve Sep 6, 2010
Plumbing Forum, Professional & DIY Advice Shutoff valve quality? Jul 17, 2009
