Good Pressure; Poor flow
mijway
I have a well with a submersable pump. Water flow has dropped significantly. Pressure switch is 20/40 psi. Air pressure in tank is 18 psi. Pump kicks on at 20 psi, jumps to 25 psi, and continues to 40 psi. However, water flow remains very low.
Problem was first discovered while watering the lawn and noticed that water flow had stopped. Pressure gauge showed zero. I tripped the circuit breaker and waited until the next day. Next day the system worked OK for a while. Then water flow diminished to a level that would not operate the sprinkler head.
Where do I start looking for the problem? Water lines, tank, pump, well?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If the pressure climbs to 40 and the pump shuts off while you are running the sprinkler, a filter or water line is clogged. If the pressure does not rise while you are running the sprinkler, the pump or the well is the next place to look.
mijway
I just tested the system again. There was improvement, but still below par.
The pump does come on while the sprinkler is running and builds to 40 psi before kicking off. I tested the water flow in a five gal. bucket for both the front and rear valve.
Rear 2.7 gal/min
Front 1.9 gal/min
Rear 2.7 gal/min
The only filter would be in the pump.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If you don't have a filter, then something is restricting the line out to the sprinklers. If the pump can still build to 40 and shut off while the sprinkler is running, your pump is moving plenty of water and it is just not able to get to the sprinklers.
mijway
The pipe from the well is plastic and drops down about 42" to galvanized piping that goes to the pressure tank, pressure switch and pressure gauge. The galvanized piping then connects to copper distribution piping.
The house is about 32 years old and I assume this is the original system. Public water was added sometime later, so the well water is plumbed for outside purposes only.
I plan on replacing all of the galvanized pipe.
Is it OK to use plastic pipe?
Can I replace the pressure switch with a 40/60 psi switch?
Would it be a good idea to replace the pressure tank while I am at it?
Is there some information depository where I can find out the age of the well, depth, etc.?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
It is the pipe leaving the pressure tank and going to the sprinklers that is restricted. The tank is getting plenty of water, or the pump would not build up and shut off, while pressure is low at the sprinklers. Raising the pressure may help, as long as your pump can build that much pressure. But if you raise the pressure switch and the pump can't cut off, you will have to turn it back down.
mijway
Thank you valveman. I went online and did find the original data for my well.
Date: 7/18/1974
Depth: 95 ft.
Casinf Dia.: 4 in.
Casing lenght: 54 ft.
Aquifer: shale
Static water level: 50 ft.
Drawdown: 5 ft.
Test Rate: 40 gpm
Test Duration: 1 hr.
mijway
I increased pressure setting to 50/30 psi and have significant improvement. Have not rechecked gpm to see if anything has been dislodged in the lines.
PoppyBear
North Carolina
Online data on well
Hello Mijway, can you tell me where you searched online to find the info on your well? I need information on my well but I don't know where to start. Thanks for any help!
Bill
