Gluing CPVC pipe with PVC cement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by angela1kevin1, Nov 15, 2006.
  1. angela1kevin1
    angela1kevin1 New Member
    Nov 15, 2006
    Is this a major no-no.
    I am in the process of remodeling my basement bathroom and I was installing cpvc lines for my sink, washer, and utility sink. I did not know that there was even cpvc cement. So, i was using regular pvc cement. I was told that the cpvc cement will hold up better for the hot lines. Do i need to redo the lines and glue with cpvc or will the pvc cement do just fine?
    Any help will be greatly appreciated.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    What you must understand is that CPVC, PVC, and ABS are not actually "glued" together. They are joined by solvent welding, much like metal welding except the process is done chemically rather than by heat. The solvent, aka "glue", temporarily liquifies the top layers of the pipe and fitting. The pieces are slipped together and the liquified materials from each piece blend together. Problem is, since each of these three types of pipes are different chemically, they each require a solvent specifically for that type of material. In short, you must redo the job using CPVC solvent.
Similar Threads: Gluing CPVC
Plumbing Forum, Professional & DIY Advice CPVC gluing wait time in cold temps Jan 17, 2009
Plumbing Forum, Professional & DIY Advice gluing CPVC Nov 15, 2006
Plumbing Forum, Professional & DIY Advice Turning while gluing PVC fittings Dec 7, 2015
Plumbing Forum, Professional & DIY Advice Gluing up an undersink connection May 18, 2015
Plumbing Forum, Professional & DIY Advice Re-gluing a coupler Mar 16, 2015
