Gluing ABS pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by daz49, Jan 29, 2009.
  1. daz49
    daz49 New Member
    Jan 29, 2009
    My question is about 3" ABS pipe
    l've roughed in my toilet 12" from the finished drywall. l now want to install tiles and therefore need another 5/8". l have yet to secure the toilet flange to the sub floor and therefore can pull the flange 5/8 from the wall which in turn is bending the 3" pipe and connections running from the flange to the main stack about 4' away. So my question is will this stress on the glued ABS joints over time loosen and start to leak?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It is a very common misconception that ABS and PVC pipes are "glued" together. The process that joins them is very similar to welding steel. The process is done chemically and is called solvent welding. The so-called glue is actually a solvent that briefly melts the top surfaces of the pipe and fitting and allows the two surfaces to combine when the joint is assembled. Then the surfaces harden and the joint is complete. While ABS and PVC are different chemically and require their own solvents, the process is essentially the same. Your joints will be fine. The main thing is when assembling the pipes, don't move a joint for a minute or so after assembly so that the solvents can set without cracking.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Stressing any connection increases the chances of cracking.
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    This post sounds chillingly familiar :confused:
  6. Terry
    Aug 17, 2004
    Many toilets have 3/4" of space behind on a 12" rough.
    Which toilet are you using?
  7. daz49
    daz49 New Member
    Jan 29, 2009
    Toto aquia II
Similar Threads: Gluing pipe
Plumbing Forum, Professional & DIY Advice 3" PVC PIPE Gluing Question Sep 24, 2012
Plumbing Forum, Professional & DIY Advice Gluing CPVC pipe with PVC cement Nov 15, 2006
Plumbing Forum, Professional & DIY Advice re-gluing abs drain pipe Apr 9, 2006
Plumbing Forum, Professional & DIY Advice 'Ungluing' pvc dwv pipe? Apr 29, 2005
Plumbing Forum, Professional & DIY Advice Turning while gluing PVC fittings Dec 7, 2015
