GFI in series?
Discussion in 'Electrical Forum discussion & Blog' started by Fishman43, May 1, 2008.
  1. Fishman43
    Fishman43 New Member
    May 1, 2008
    Hello All,
    If I have four standard outlets in series in my kitchen along the counter top and wanted to convert them to GFI, can I replace the first outlet in the series with a GFI and will that cover all of the down stream outlets?
    Thanks
  2. PEW
    PEW DIY Senior Member
    Yes, if wired per the instruction with the GFCI.
  4. jadnashua
    Almost all (but not every one) gfci outlets let you daisy chain additional outlets to protect them. If the gfci has connections for both load and line, anything connected to the load side is protected as well as the gfci itself (of course!).
  5. Marv
    Marv New Member
    May 7, 2008
    Accountant
    Northern Illinois
    You really need to know what is all the way down the line. Hopefully your refrigerator is not on the line and kicks the breaker when you're not around.
  6. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    If it does, its a good warning sign your fridge is failing. ;)
  7. Marv
    Marv New Member
    May 7, 2008
    Accountant
    Northern Illinois
    I have a 1 year old fridge at the office (full size) that just started to trip the GFCI its plugged into. I think its just because the motor is drawing a little extra current as it ages. I plugged it into another outlet and its fine. Motors can often trip a GFCI.
  8. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    When they start leaking current. Just because it works in a nongfci outlet, does not mean it is not leaking current. It has been years since I have seen a false trip on a gfci.
Similar Threads: series
Electrical Forum discussion & Blog Wiring lights in series with switch loop at the end Jun 24, 2016
