GFI adding WH
Discussion in 'Water Heater Forum, Tanks' started by Spook, Jan 26, 2012.
  1. Spook
    Spook New Member
    Jan 26, 2012
    retired
    Florida
    Can I plug a 110 water heater into a GFI protected outlet, or will it trip everytime it cycles?
  2. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    You can if you dont exceed the amperage of the outlet and wire. It should have its own circuit. A dedicated outlet/circuit for that water heater only.
Similar Threads: adding
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Questions about over flow value and adding a expansion tank Feb 3, 2013
Water Heater Forum, Tanks adding a light switch to GFI protected circuit Jan 26, 2012
Water Heater Forum, Tanks Adding 2nd holding tank as pre-heat for incoming water Jun 2, 2009
Water Heater Forum, Tanks adding another hot water tank Jan 14, 2009
