GFCI wiring
Discussion in 'Electrical Forum discussion & Blog' started by bradleyheathhays, Jun 2, 2014.
  1. bradleyheathhays
    bradleyheathhays New Member
    Jun 2, 2014
    95124
    Installed a new Cooper ShockSentry GFCI / DDFT / ICTA outlet in an outlet box that had no ground. White to silver and black to gold, without being grounded will this outlet trip correctly? It'll be handling close to a 10 amp load powering a large aquarium.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Yes.......
  4. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    You are good to go.
    The only problem, and it is not much of one, is that the test requires a ground to shunt a little current from the hot to ground, which you don't have.
    I use a plug in polarity tester that also tests gfis, and it won't test if there is not a ground, for the same reason.
    You have made the outlet infinitely safer by putting in the gfi.
  5. jadnashua
    A GFCI trips when the current on the hot and neutral are different. In a properly working circuit, all of the power that goes into it on the hot lead must return on the neutral. When they get out of balance, that means some has 'faulted' to ground, and it 'interrupts' the circuit (i.e., trips). Most work when that difference exceeds about 0.005A (5ma). It does not need a ground to cause it to trip at the device. Overloading the device will (or at least should) cause the circuit breaker or fuse to shut off power as well - two different things - one is protecting you (or your fish!), and the second is protecting the wiring from overheating.
    THey work. The receptacle should be marked with one of the labels that came with it indicating it does not have a ground wire attached.
  6. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    A real good reason if you happen to be pushing the test button and touching a grounded/earthed metal cover plate at the same time.
Similar Threads: GFCI wiring
Electrical Forum discussion & Blog Wiring a GFCI May 27, 2011
Electrical Forum discussion & Blog Wiring bathroom exhaust fans, GFCI concerns, NEC concerns. Aug 12, 2010
Electrical Forum discussion & Blog Correct wiring of GFCI Breaker Feb 19, 2010
Electrical Forum discussion & Blog Wiring Bathroom/GFCI Circuit Jan 19, 2010
Electrical Forum discussion & Blog GFCI replaced, now regular outlet is dead Feb 14, 2016
