GFCI receptacle questions
Discussion in 'Electrical Forum discussion & Blog' started by DIY, May 16, 2014.
  1. DIY
    DIY Member
    Dec 24, 2006
    Florida
    Hi all, Today I finally got the chance to take a look see at this 2 bedroom/ 1 bath duplex for sale. It all looked to be in good shape inside and out, for being built in the late 50's,It has numerous upgrades, but the thing that seemed odd was at all of the 14 outlets per 2 bedroom was a GFCI receptacle. After some more poking & looking around I found there was no ground wire at any of the 14 GFCI outlets either.(just a black hot wire, and a white neutral wire) Does anybody out there know if a ground wire can be run from a bus bar in the fuse box to each GFCI receptacle? or Is a label needed like GFCI PROTECTED OUTLET/NO EQUIPMENT GROUND or something to let a user know what he or she is going to plug into. Thank you
  2. Stuff
    Stuff Active Member
    Mar 7, 2013
    Pennsylvania
    You are correct that the stickers need to be applied since the GFCI has no real grounding conductor. Yes, you can run a grounding wire back to the main panel but usually the effort involved is almost as much as running a new 14-2 w/g cable.
    For bedrooms, etc. it would have been cheaper and code compliant (for most locations) to buy some two prong receptacles.
  4. houptee
    houptee Member
    Aug 27, 2008
    Home Improvement Contractor
    Monmouth County, NJ
  5. DIY
    DIY Member
    Dec 24, 2006
    Florida
    Thank you , Stuff and Houptee for your replies to my GFCI question.
    Stuff, in answer to your suggestion about installing 2 prong outlets. The GFCI outlets replaced 2 prong outlets the owner told me.
    Houptee,That was a great read about grounding and GFCI outlets you sent me. Many thanks
  6. hj
    quote; For bedrooms, etc. it would have been cheaper and code compliant (for most locations) to buy some two prong receptacles.
    ANd then buy a bucket full of "3 to 2" prong adapters and cut the ground wire off of them. MUCH Safer, right?
  7. jadnashua
    I replaced nearly all of the 60-year old 2-prong units at my mother's house with quality 3-hole receptacles...with enough GFCI versions to cover all of them in the house...I think it ended up needing about 7 gfci units and about 20 'normal' ones. It took some detective skills to see which ones were on which legs, and to find the first one (last is always easy!), but by doing that, saved a huge amount by using the daisy-chain protected output of the GFCI units. There were a few places where there were ground wires (like when they updated the kitchen), but I replaced them anyway...years of in/out and some heavy current uses had made them poor connections. When new, the armored cable may have provided a reasonable ground, but buried in the plaster and decades of seasonal changes, and that was essentially useless. So, the only way to plug in typical grounded plugs was an adapter, and less than reliable safety. The GFCI protection is much better than nothing, and much less than a major rewire.
  8. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Installing a GFCI in the place of a 2 prong receptacle is code approved. In the case that there are multiple receptacles on the same circuit, it might be cheaper to install a GFCI breaker on the circuit if the panel will accept one.
    The ungrounded receptacles should be labeled as such.
  9. Stuff
    Stuff Active Member
    Mar 7, 2013
    Pennsylvania
    hj - Outside of kitchen and basement there are few devices that have a third prong/grounding pin. Even most modern power tools are double insulated and have two prong plugs.
    The MUCH Safer thing to do is re-wire the entire house.
  10. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Well.....most cheap power tools.
    Almost all my Makita, Milwaukee, Porter Cable & Bosch tools have 3-prong plugs, with a few DI thrown in.
    But you are right, VERY little in a home will have 3-prong these days. I say leave the GFI's and be done with it.
  11. DIY
    DIY Member
    Dec 24, 2006
    Florida
    I got some side info. on the GFCI outlets. The owner had the receipt of the 14 GFCI's he had gotten at lowe's (most were in a 3 pack) for 14 cooper GFCI outlets he paid $37.67!
  12. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Which for all intents and purposes is free.
    Man, that's one hell of a score.
  13. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    A GFI does not require a ground. But the ground wire provides a path to trip the breaker in event of appliance failure, If it has a three prong plug.
    Not much comes with 3 prongs, Most all computers do. Under water stuff will have a real ground also.
    The Ground may provide better protection for a device, but may not help when it comes to a Human electric shock, unless the neutral becomes open, Then it should not put out power if it is a good GFI.
Similar Threads: GFCI receptacle
Electrical Forum discussion & Blog GFCI, Dimmer Switch, Outdoor Lamp Posts with Receptacles Mar 27, 2012
Electrical Forum discussion & Blog Mysterious Tripping GFCI receptacle Dec 13, 2011
Electrical Forum discussion & Blog GFCI receptacle install Jan 20, 2010
Electrical Forum discussion & Blog Reverse connections @ GFCI receptacle Dec 1, 2009
Electrical Forum discussion & Blog 2 GFCI receptacle ?'s Jan 20, 2009
