GFCI outlet AND breaker?
Discussion in 'Electrical Forum discussion & Blog' started by hans_idle, Dec 16, 2007.
  1. hans_idle
    hans_idle New Member
    Sep 16, 2007
    Sitting on my butt at a desk all day
    Princeton Junction, NJ
    I'm working through my master bath remodel. The previous whirlpool was on a 120V GFCI breaker. The same circuit also powers the bathroom fan. The new airbath tub runs on the same voltage, so I can re-use the same circuit.
    Whereas the old tub was hardwired to the electrical service, the new tub comes with 3-prong plugs for the turbine. I figured I'd install an outlet under the tub (which is accessible by a hatch) to plug the turbine/heater into.
    The question I had was whether or not I could/should use a GFCI outlet given that there is a GFCI breaker. I had heard that you shouldn't hook multiple GFCI outlets on the same line, but I don't know about an outlet and a breaker.
    Is the combination necessary, not necessary, illegal, overkill, etc.?
    My primary reason for having the GFCI local was so that the reset was local to the tub. But since the fan was also on the outlet, I figured maybe I should keep the breaker in place for the whole circuit.
    Thanks for any advice.
    -Hans
  2. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    Electrical Contractor
    Who's to say which GFI will trip in a fault condition? It's a 50-50 chance the one in the panel will trip, so you're back to getting dried & dressed to go reset it.
    Why not just replace the GFI breaker with a standard one?
  4. jadnashua
    There is no advantage to having two devices in series. Me, I'd leave the breaker and replace the outlet. Having to remove a panel is more work than checking the breaker. It should only trip on a fault, and that shouldn't happen often. If it is behind a panel, you are also much less likely to test it as the instructions say you should monthly, too.
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    So if you are in a tub and it trips out are you saying to get out and reset it and then without future ado just jump back in?
    Wonder what caused it to trip?
    Would it be safe to just jump back in?
  6. hans_idle
    Sep 16, 2007
    Good points. I'm thinking that I'll just keep the breaker in place since the bathroom fan is also on it. It's outside the shower by about 2 feet on the ceiling, but it should stay on a GFCI line.
    My only "real" concern was seeing that some people had posted that the inspector wanted to see a reset switch "nearby", whereas in my case you'll have to trudge into the basement. I'll just have to see what the inspector says.
  7. rdtompki
    rdtompki New Member
    Dec 21, 2005
    Iowa
    Your fan doesn't have to be on a GFCI breaker and some brands of fans can cause false trips. Go ahead and leave it on, however, if you've had no problem to date unless the inspector wants to see the tub on a separate breaker. Often the directions for the tub will specify a separate breaker.
    Rick
  8. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    I wouldn't worry much about what any inspector "wants" and only concern myself about what is required and nothing requires the reset to be close by the appliance.
  9. hans_idle
    Sep 16, 2007
    Actually, in this case, both the previous and new tub manufacturer want the tub to be on its own circuit. Since the previous tub was actually sharing a circuit with the fan, I was going to keep it that way. It's a 20A line, with the tub (turbine and heater) drawing 1600W. So it seemed like there was capacity for the fan.
    Any other reasons (besides capacity) as to why the 2 can't be on the same circuit?
Similar Threads: GFCI outlet
Electrical Forum discussion & Blog GFCI replaced, now regular outlet is dead Feb 14, 2016
Electrical Forum discussion & Blog Bathroom outlets tripping garage GFCI Nov 15, 2015
Electrical Forum discussion & Blog Do GFCI Outlets Need a Ground? Nov 14, 2014
Electrical Forum discussion & Blog Is this box too small for this GFCI outlet? Dec 15, 2011
Electrical Forum discussion & Blog GFCI's at all outlet locations Aug 17, 2011
