GFCI outlet / 2 lights / switch at end of run
Discussion in 'Electrical Forum discussion & Blog' started by rioguia, Dec 30, 2007.
  1. rioguia
    rioguia New Member
    Jan 21, 2007
    I'm running power from a GFCI outlet to two lights with a light
    switch on the end of the power run using 12/2 wire. I have made a diagram giving the details (see link below).
    1. Is this a correct configuration?
    2. Will the lights and switch be protected by the GFCI (assuming I wire the GFCI correctly?
    GFCI diagram.
  2. jadnashua
    If you run the leads to the switch and lamps from the load side of the gfci, yes. Normally you'd continue the black to the switch and then designate the white as the switched lead with some red tape on each end.
  4. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Nope, he has it right.
    The re-designated white should be the constant hot wire, the already-black wire is the switched.
    I don't know why, and I'd have to dig a bit for the threads, but all the sparkies agree on it. It struck me as counter-intuitive, too, but that's the industry standard, apparently...
    okay, I didn't have to dig that far:*
    Apparently it's a code violation to do it otherwise.
    *Standard JLConline link disclaimer: it's a pro-only site, and some people there can get pretty rude about it. If you're not an industry pro, you can read as much as you want, you can even register (allows you to download attachments, and saves you having to type a verification code when you search), but DO NOT POST there. Nobody will answer you, and they'll pick on you, as well. Exceptions to this rule: the electrical sub-forum, and the building-science sub-forum, are open to anyone.
Similar Threads: GFCI outlet
Electrical Forum discussion & Blog GFCI replaced, now regular outlet is dead Feb 14, 2016
Electrical Forum discussion & Blog Bathroom outlets tripping garage GFCI Nov 15, 2015
Electrical Forum discussion & Blog Do GFCI Outlets Need a Ground? Nov 14, 2014
Electrical Forum discussion & Blog Is this box too small for this GFCI outlet? Dec 15, 2011
Electrical Forum discussion & Blog GFCI's at all outlet locations Aug 17, 2011
