GFCI in bedrooms per 2009 NEC?
Discussion in 'Electrical Forum discussion & Blog' started by Thurman, Feb 19, 2009.
  1. Thurman
    Thurman New Member
    Jan 29, 2009
    During a conversation with two (2) local, licensed residential electricians and one of the local electrical inspectors, on a job site the other day> Any new residential construction after Jan.01, 2009 requires that all 120v circuits within a bedroom be GFCI protected on either a 15 amp or 20 amp circuit, and all 120v circuits within any one bedroom may not be on one circuit. They stated that this was to bring Georgia up to par with the NEC. These electricians and the inspector say this is overkill. You're opinions? Thanks, David
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    A) There is NO 2009 NEC. It is the 2008 NEC.
    B) They are talking about AFCI, not GFIC protection.
    I have no idea where Geprgia is on this. Many locations around the country have adopted the 2008 NEC, but have placed amendments on the AFCI requirements.
    Only someone who knows the actual codes in your particular area will be able to tell you.
    I have no idea what this means.
  4. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Georgia accepted it as of Jan 1st 2009 according to this
    But as said you need to find out if it was accepted in full
    http://www.childoutletsafety.org/files/NECAdoptionMap.pdf
    Also Tamper proof required everywhere (pretty sure)
    Outside must be tamper proof, weather resistant & GFCI
    I think those are the changes - we've been on int since Jan 1st 2008
    I just returned $52+ of 20a PRO heavy duty outlets I can't use
    And they don't have any 20a PRO tamper proof :mad:
    Plus the price is double now
  5. codeone
    codeone Code Enforcement
    Sep 5, 2008
    Code Enforcement, Instructor
    North Carolina
    NEC 2009 AFCI
    210.12 Are-Fault Circuit-Interrupter Protection.
    (AFCI)
    (B) Dwelling Units: All 125-volt, single-phase,
    15- and 20- ampere branch circuits supplying
    outlets installed in dwelling unit family rooms,
    dining rooms, living rooms, parlors, libraries,
    dens, bedrooms, sunrooms, recreation rooms,
    closets, hallways, or similar rooms or areas
    shall be protected by a listed arc-fault circuit
    interrupter, combination-type, installed to
    provide protection of the branch circuit.
    NC addopted the 2008 NEC last year Mandatory Starting JULY 3 2008
    with some exceptions. This section was delayed until JAN 1 2009
  6. Thurman
    Thurman New Member
    Jan 29, 2009
    Maybe a little more info and clarification as to what this was all about: It is a State of Georgia Amendment to the 2008 NEC, and is about arc-fault and not GFCI. The link I found is very long but it falls under Georgia's Amendments: "210.12 Arc-Fault Circuit-Interrupter Protection." From what I found it still doesn't explain them talking about not having all duplex outlets in one bedroom on a single circuit, although having the outlets in one room divided up on different circuits is the way I was taught to wire a room so if one circuit fails, you have another for lighting, etc. It seems to be that with any new ruling or amendment to a ruling it takes time for interpretation. I'm still learning every day about something. Thanks, David
  7. Chrissimms
    Chrissimms Master Electrician
    Oct 13, 2008
    Master Electrician
    Cohutta GA
    Georgia has had arc fault breaker requirements in bedrooms only for several years now. As of 1/1/09 GA has adopted the tamper resistant receptacles in most counties.
    Chris
  8. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
Similar Threads: GFCI bedrooms
Electrical Forum discussion & Blog GFCI tripping with no load when connected to power Oct 7, 2016
Electrical Forum discussion & Blog GFCI shared neutral Aug 8, 2016
Electrical Forum discussion & Blog GFCI replaced, now regular outlet is dead Feb 14, 2016
Electrical Forum discussion & Blog Bathroom outlets tripping garage GFCI Nov 15, 2015
Electrical Forum discussion & Blog Cutler GFCI May 29, 2015
