getting rid of hammer
Discussion in 'Irrigation / Sprinkler Forum' started by v1rtu0s1ty, Aug 24, 2009.
  1. v1rtu0s1ty
    v1rtu0s1ty DIY Senior Member
    Sep 18, 2006
    Chicago IL
    I built a homebrew automated sprinkler system with the use orbit 3/4" sprinkler valves and garden hoses. It's just connected to the spigot outside. That means, it's temporary and I will have to remove it in winter. It's working pretty well.
    However, eventhough it's temporary, I would like to address an issue that I am experiencing. There are times when it turns off, I will hear a loud hammer on the pipes. About 85%, it happens. Are there any ways to prevent it without putting a hammer arrestor? I'm looking for a temporary solution if there are any.
    http://i303.photobucket.com/albums/nn134/s1mpl3k1d/LawnRenovation2009/lawnsprinklervalves20090814.jpg
    Neil
  2. upper
    upper DIY Senior Member
    May 30, 2009
    Fresno, CA
    What type of valves.And how is it piped between the valve and the faucet? Upper
  4. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
  5. Terry
    Aug 17, 2004
    The easiest fix would be to remove the brass hose bib with galvanized coupling,
    Replace the coupling with a threaded tee, and insert a threaded hammer arrestor in one side of the tee.
  6. tomm
    tomm New Member
    Feb 21, 2008
    what/how many heads are connected at the end of the hoses? how long are the hoses? what is the pressure?
  7. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    That's a very cool idea! I'm going to print out my picture and bring it to the store. Thank you so much!!! :D
  8. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    1st valve - one oscillating sprinkler
    2nd valve - one oscillating sprinkler
    3rd valve - 3 impact sprinklers
    The garden hoses pipe lengths are somewhere 60ft long per.
    I think the length of the garden hose doesn't matter. It's because, the hammer happens before the sprinkler valve.
Similar Threads: getting hammer
Irrigation / Sprinkler Forum Not getting water through backflow preventer May 17, 2015
Irrigation / Sprinkler Forum New plumbing created water hammer noise in 3 irrigation zones Apr 10, 2014
Irrigation / Sprinkler Forum Second set of valves is causing watering hammer? May 25, 2011
Irrigation / Sprinkler Forum Water Hammer in lawn system Nov 24, 2008
Irrigation / Sprinkler Forum Irrigation Solinoid Zone Valve "Hammering" Oct 16, 2008
