Getting fancy--replacing pressure valve w/ thermostatic valve
Discussion in 'Shower & Bathtub Forum & Blog' started by PreciousBusterbird, Feb 11, 2009.
  1. PreciousBusterbird
    PreciousBusterbird New Member
    Jan 16, 2009
    Hello--I have a question. Pressure balanced or thermostatic?
    I'm replacing my tub and tiling the alcove, so now is the time to do other little upgrades. So I got the Hansgrohe Raindance Connect and have decided I need to change out my Delta Monitor 17000 volume control/temp (pressure-balanced), trim, and tub spout w/diverter.
    I want to get a Hansgrohe thermostatic valve, trim, and tub spout with no diverter. The trim has the added feature of an integrated diverter so I will have a nice clean tub spout.
    The thing is, I could use my existing Delta stuff with the new shower. But will I regret not having a thermostatic valve? It seems as though people really like them.
    Thanks very much.
    -Casey
  2. hj
    Delta
    Then buy a Delta themostatic 1700 T cartridge and put it in your valve.
  4. PreciousBusterbird
    Jan 16, 2009
    Thanks for the suggestion, but apparently the 17T will not fit my older 1700. From what I have seen on this forum, it looks as though the thermo is the way to go. So - I will go thermo with new stuff.
    Thanks again.
  5. hj
    When I installed my 1700, not the new universal body, it was thermstatic adaptable even though the control was not available. I will have to check with Delta, but from my observation, ALL 1700 cores are the same, regardless of age. Unless you do not really have a 1700 with the separate volume and temperature handles.
  6. PreciousBusterbird
    Jan 16, 2009
    Hi hj - thanks for the reply. It is definitely a Delta 1700, with temp and volume adjustments. I was basing the unavailability on a diagram I found on this forum in this post:
    http://www.terrylove.com/forums/showthread.php?p=182222
    There is a cartridge summary reference sheet pictured there that I interpreted to mean that my version wouldn't work with a T valve.
    This is all quite new to me so I appreciate your willingness to share your knowledge. Thank you.
    -Casey
Similar Threads: Getting fancy--replacing
Shower & Bathtub Forum & Blog Wall adjacent to shower getting wet Dec 9, 2015
Shower & Bathtub Forum & Blog getting the right paint color for bathtub repair Jun 8, 2014
Shower & Bathtub Forum & Blog Hot Showers - Getting the temperature just right, Top Five Tips from the pros Apr 28, 2014
Shower & Bathtub Forum & Blog Getting a standard 5" tub through RO Oct 23, 2011
Shower & Bathtub Forum & Blog Getting strainer off Oatey shower drain Jun 2, 2010
