Getting a snake through a p-trap?
Discussion in 'Drain Cleaning' started by pedietz, Nov 14, 2006.
  1. pedietz
    pedietz New Member
    Nov 14, 2006
    My pedestal sink is so close to the wall that I can't get a wrench on the clean-out on the bottom of the trap. Any suggestions on getting a snake through the trap? The drain appears to be blocked about 4 - 6' away from the sink, for what that is worth.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Remove the pop-up drain piece, unscrew the lift rod and back it out and run the cable top down.
    Don't let the cable come in contact with the porcelain, it will damage.
    Otherwise you'll be taking that trap apart somehow, or taking the pedestal sink off the wall to access the drain.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    I use a small cable in a tapered can with an offset handle and just wind it through the trap. It's stiff enough to get through the trap and It makes 90o turns quite easily and you may not be any more than 5 feet to a stack.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    This might be a good situation to use one of those drain cleaning bladders.
  6. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    You use it, I sure won't....
  7. pedietz
    pedietz New Member
    Nov 14, 2006
    Clarification?
    Why no drain cleaning bladder? Does it matter if the drains are cast iron, not PVC?
  8. Dunbar Plumbing
    Apr 18, 2005
    They are no good if there is a tee in that line serviing as a vent before the clog.
    I've seen best results with those on floor drains where the piping is collapsed and no cable will pass through.
    Some swear by those fast action air movers that drano sell. The commercial alone is enough to gross even me out.:eek:
    If you use a drain bladder it can force compression joints to blow apart/cause them to leak after the drain is open.
Similar Threads: Getting snake
Drain Cleaning slow drain - having trouble getting 1/2 inch snake into sink drain Oct 30, 2014
Drain Cleaning Help - Upstairs Toilet Drain Keeps getting clogged with Toilet Paper Aug 1, 2012
Drain Cleaning Getting #*$% drain auger past 90. Oct 19, 2010
Drain Cleaning drain auger, problems w getting it in far enough Jun 9, 2008
Drain Cleaning Drain still clogged after being snaked. Oct 9, 2015
