GE Smartwater Leak
Discussion in 'Water Heater Forum, Tanks' started by Phillbo, Mar 19, 2014.
  1. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    I have a 50gal GE water heater that has developed a leak where the hot water line exits the top of the tank. There is a little depression where the fitting connects and it's full of water. I tried putting a wrench on it to tighten the fitting but could not budge it. It appears to be tight.
    Is this a sign of needing a new water heater? This one is 10 years old.
  2. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Not necessarily, if the leak comes from the flex connector's nut. Could be a worn out washer inside.
  4. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    If you have a flexible supply line on the hot water outlet, as dj2 noted, try to tighten the connection nut and see if it helps. If not and you see water coming from where the nut is, shut off the water and remove the hot water outlet connector. Check to make sure the rubber washer is in the end of the nut and looks to be in good shape. Re-install the supply line and check for leaks.
    If the above did not fix your leak or if you have rigid pipe connected to the water heater hot outlet, it would then appear the tank is rusted out at the connection. Change out the water heater. It stinks but 10 years is not an unusual life span for a water heater.
  5. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    Thanks guys. I took a better look at it and it appears the flex connector has rusted to the point that it is leaking. I have my plumber coming out this afternoon to replace the line.
    It must have had a small leak for a while.
Similar Threads: Smartwater Leak
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks T&P Valve Leak Mystery Jan 25, 2017
Water Heater Forum, Tanks Sounds like pop off valve leaking.... Dec 8, 2016
Water Heater Forum, Tanks Leaking stainless braided water heater hose. Dec 5, 2016
Water Heater Forum, Tanks Condensation or Leak? Nov 28, 2016
