GE hybrid water heater install with power company load management system
Discussion in 'Water Heater Forum, Tanks' started by dutzig, Dec 15, 2010.
  1. dutzig
    dutzig New Member
    Sep 12, 2009
    FL
    I purchased a GE hybrid water heater that is not yet installed. It did not occur to me until today that my current water heater is connected to my power company's (Progress Energy in FL) EnergyWise load management system, which allows them to cycle off my water heater in exchange for a monthly rebate. I'm concerned that the additional electronics of the GE hybrid will not like this. I reviewed the installation manual and there is nothing that discusses this topic. Any thoughts?
    Thanks in advance, Doug.
  2. dutzig
    dutzig New Member
    Sep 12, 2009
    FL
    I received this response from GE
    The GeoSpring water heater can be used with your power company's EnergyWise load management device, but GE recommends that you do not use the device because it may actually increase your energy consumption. Here's how. The GeoSpring is designed to maximize energy efficiency by using the heat pump as the primary means to heat the water, but GeoSpring also has standard electric elements that can be energized if the water temperature in the tank falls too low indicating a high hot water demand situation. This allows the GeoSpring to maximize energy efficiency under normal conditions, but also allows GeoSpring to recover just like a standard electric water heater under high demand conditions. Consumers get maximum energy efficiency without sacrificing performance. The EnergyWise device turns power on and off to your water heater. This could present a problem if the water temperature drops too low during an off period. When the unit is reenergized, it will sense a low water temperature in the water heater and energize the less efficient standard electric elements to recover the water temperature more quickly (it will respond like a high demand situation). Had the EnergyWise device not been used, power would not have been interrupted to the water heater, and the GeoSpring would have used the heat pump to more efficiently maintain the water temperature at the setpoint level. By using the standard electric elements, you will have used more electricity and reduced your savings. The heat pump is up to 62% more efficient at heating the water than the standard electric elements. Anything that causes the standard electric elements to energize instead of the heat pump will reduce your efficiency and energy savings, and per the explanation above, this device has the potential to cause the standard electric elements to operate unnecessarily.
Similar Threads: hybrid water
Water Heater Forum, Tanks Hybrid water heaters and types of issues. Aug 6, 2014
Water Heater Forum, Tanks Replacing two independent water heaters with one new hybrid water heater? May 8, 2014
Water Heater Forum, Tanks AirGenerate AirTap Hybrid Heat Pump Water Heater Aug 15, 2012
Water Heater Forum, Tanks GE Hybrid water heater, Tips to get it running again? Jul 14, 2012
Water Heater Forum, Tanks Hybrid water heaters Jan 9, 2010
