Gate Valve on 2" Ejector Basin discharge line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rich_B, Apr 7, 2008.
  1. Rich_B
    Rich_B New Member
    Mar 6, 2006
    :confused:I know a gate valve is required on the 2" DWV line upstream from the check valve from the ejector pump basin. What's the purpose for the gate valve if it's always opened? Is it used to regulate/restrict the diameter to avoid possible air hammer/chatter during discharge?
  2. jadnashua
    I don't know about the type of valve, but I'd want a valve there in case I needed to repair, replace, or service the check valve, pump, or tank...you wouldn't want a hiccup letting the sewer back up on your head while you had things apart.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    No it is to keep the sewage from draining back if you have to replace the check valve. It should be left in the wide open position at all other times...
    Some systems can have quite a bit of head on them and without a valve it would be a bad day for a plumber and your basement!
    Personally I would quote a really crazy $$$$ to do the work and sincerely hope that that you found someone cheaper to do it!
  5. Rich_B
    Rich_B New Member
    Mar 6, 2006
    Ok...makes really great sense now. I'm doing the work myself and would not install the line without it....just never considerd the possible amount of "head" that could be in the line...or replacing the check valve.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Yea, I did a job on one where the line was on an uphill for about 400 feet... Imagine 400' of 2" dia. liquified poo coming at ya!:eek:
    Fortunately there was a valve!
Similar Threads: Gate Valve
Plumbing Forum, Professional & DIY Advice Replace Gate valve (no pipe slack) Aug 1, 2016
Plumbing Forum, Professional & DIY Advice Repair Older Nibco S-29 Gate Valve Dec 15, 2015
Plumbing Forum, Professional & DIY Advice Replace gate valve advice? May 5, 2015
Plumbing Forum, Professional & DIY Advice Question about a gate valve Mar 26, 2015
Plumbing Forum, Professional & DIY Advice Main gate valve broken in "shut off position". Jan 5, 2015
