gasket on tub overflow
Discussion in 'Shower & Bathtub Forum & Blog' started by jvl, Dec 21, 2007.
  1. jvl
    jvl New Member
    Dec 9, 2007
    California
    hello,could somebody explain the proper installation of the gasket on the overflow on the bath tub.i see that the gasket tapers from a thick to thin.does this apply to the curvature of the tub.please explain.thanks jvl
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If you have the right gasget for your tub, and it is tapered, the narrow end goes down and the thicker goes up.
  4. hj
    gasket
    You position the overflow fitting behind the tub and then rotate the gasket until it fills the entire opening, even if you have to twist the overflow fitting so it is not parallel to the tub face.
Similar Threads: gasket overflow
Shower & Bathtub Forum & Blog Bath Overflow drain Gasket issue Jan 7, 2013
Shower & Bathtub Forum & Blog Overflow gasket wrong taper for old tub Jan 1, 2013
Shower & Bathtub Forum & Blog question about possible worn gasket behind bathtub overflow plate May 9, 2010
Shower & Bathtub Forum & Blog Leak from overflow gasket on tub drain Nov 21, 2009
Shower & Bathtub Forum & Blog drain and overflow rubber gasket problems.. Mar 21, 2008
