gas water tank leak
Discussion in 'Water Heater Forum, Tanks' started by kbedford, Mar 31, 2010.
  1. kbedford
    kbedford New Member
    Mar 31, 2010
    oakdale, ny 11769
    hi - i have a richmond 7k50 gas water heater. it is leaking from the drain valve. does this spell doom for the heater? thanks
    keith
  2. jadnashua
    If it is just the valve, you can replace the valve. If it is leaking around where the valve goes into the tank, you probably need a new tank. If you are referring to the T&P valve at the top of the tank, that valve may be bad, or you have other problems. The T&P valve opens for several reasons: it's worn out, the water is too hot, the pressure is too high. If it is leaking, you need to find out which is the problem (or problems). Over pressure can be caused by more than one thing, and the solution depends on what's going on.
  4. kbedford
    kbedford New Member
    Mar 31, 2010
    oakdale, ny 11769
    thanks jim - it is leaking from the valve near the bottom - used to drain the tank.
  5. hj
    If it is brass it will unscrew, but may take some ingenuity to grab hold of it. If it is plastic, it will probably snap off and then it can be a challenge for a DIYer to get the broken piece out. A hose valve cap will stop the leaking.
Similar Threads: water tank
Water Heater Forum, Tanks Low amperage, lowest cost point of use electric water heater tank for low volume use? Jan 31, 2017
Water Heater Forum, Tanks Expansion Tank, and other water heater questions.......... Jan 28, 2017
Water Heater Forum, Tanks Replacing Solar Hot Water Tank Jan 10, 2017
Water Heater Forum, Tanks Best Tankless Water Heater Brand? Jul 8, 2016
Water Heater Forum, Tanks Water heater tank flushing process Jun 13, 2016
