- Messages
- 33,603
- Reaction score
- 1,042
- Points
- 113
- Location
- Cave Creek, Arizona
- Website
- www.terrylove.com
shock
quote; This is a false statement as current will take every possible path available to it. If current always took the path of least resistance how can a human ever feel electrical shock? Wouldn’t the current choose to travel on a path of lesser resistance?
In that situation, the human being is the ONLY path, regardless of the amount of resistance. Or to put it another way, if you grab two wires and get a shock, WHAT or WHERE would be "the path of lesser resistance? If there is a "path of lesser resistance", which could indicate either usage, such as a light bulb although that would usually be a higher resistance, or a short circuit, the circuit breaker should trip, and if not, there is a serious wiring problem. In any case, installing the jumper may be "voodoo science", but it seems to cure the problem. Or at least the problem does not reoccur for some reason, regardless of what cures it.
