Gas water heater bonding
Discussion in 'Electrical Forum discussion & Blog' started by ankhseeker, Jan 8, 2014.
  1. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    That would be refreshing.
    Because the metal pipe was removed, there is no longer the need for the jumper to cure the RFI that was the reason this particular jumper was placed. The fact that it can prevent some water heater corrosion was lost on me at the time the jumper was placed, but those currents also got removed when the jumper was placed. However with the CPVC, those currents still not occur, so that problem was taken care of too.
    What is this "landing" word? (seriously) What is this "bonding" word? Is a metal strap holding up a metal pipe "bonded" What if that strap holds up two metal pipe... OH Ohhh... Gotta run a wire from that strap to a "landing"? (semi-seriously) Sheesh. Is your bonded connection ever thermite welded (not seriously), as it is often actually is in modern communication tower work? :)
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    To land a conductor is to terminate that conductor, slang talk of my area of the country. From the meter base to the rod, one end lands in the meter pan and the other end lands on the rod.
    Over the years I have done much exothermic welding. I have welded to building steel, rebar, black pipe, rods, and to other conductors. The first thing one learns is to keep the mold clean or one will be doing the same joint, another slang word for termination, many times over, well maybe gloves is the first lesson and the mold is the second. Somewhere along the line one learns to preheat the mold and to look the other way when striking the arc.
    I have worked many a day from the break of dawn to the twilight of dusk dark doing nothing but exothermic welding in a five foot, plus, deep trench that is barley 18 inches wide with the shoring in place.
    All this reminiscing I am drifting back to my school boy days and the days when I had to walk to and from school, barefoot, in the snow, and yes it was up hill both ways. I would get out of bed every morning and empty the chamber pot, take it to the creek and fill it with water that I used to clean the cow before I milked her in that pot. Take it back to the house and strain it into a wide mouth gar then back to the creek for a pot of coffee water. The first few times I washed out that old chamber pot up stream of the coffee water but I learned, downstream is better, strange how a lot of life’s lessons are learned through experience.
  3. Vegas_sparky
    Vegas_sparky Digital Billy
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    And I thought the guys on site had stories to tell. Sheeesh. LOL
  4. Rich B
    Rich B DIY Senior Member
    Sep 13, 2008
    New Jersey
    Barefoot in the snow? Chamber pot? Say what?
    What year were you born and didn't they have shoes in North Carolina then?
    I am 66.....Lived in a cold water flat as a kid.....third floor.....We had a bathroom....running water....it was cold unless we ran the nat gas hot water heater in the basement that was totally manual.....light it and be sure to shut it off once the water got hot or the pipes would bang and steam came out of the faucets. Bath night was Saturday....Coal furnace....steam heat.....radiators...
    I always had shoes.....New Jersey even had electric lights.....
    My father worked for one of Thomas A Edison's companies his entire life....he even saw Edison at the plant once. My father was a teenager or maybe 20.....Edison was close to the end of his life....
  5. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Well, being a mere 53, we had it easy. Funny thing is that is was downhill both ways from the School bus! No cows to milk, just a few dozen ducks to feed so they stayed fat and couldn't fly away.
    My Dad says that when he was little, they had running water, but in the summer they usually walked...
Similar Threads: water heater
Electrical Forum discussion & Blog Tankless water heater ... dedicated to washing machine Jul 11, 2015
Electrical Forum discussion & Blog 120v w 19 gallon water heater run on 2 pole 230v breaker. is it safe? Jul 9, 2015
Electrical Forum discussion & Blog New circuit for gas water heater Dec 7, 2014
Electrical Forum discussion & Blog Removed Electric Hot water Heater - Breaker Filler Plate? Mar 6, 2014
Electrical Forum discussion & Blog Wiring in a 220 circuit for Tankless water heater - Cunduit from behind the wall? Nov 21, 2013
