Gas suspended garage heater, how does it work?
Discussion in 'HVAC Heating & Cooling' started by snafflekid, May 4, 2007.
  1. snafflekid
    snafflekid Electrical Engineer
    Apr 23, 2007
    Electrical Engineer
    I believe that is what they are called. It is bracketed to the ceiling and hangs in a corner of the building. It runs off natural gas and has a fan on the back. What is striking to me is that there is no chimney, so the exhaust goes into the room. Is there any need I should be aware of when using this, i.e. does the room need special ventilation?
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Those types of units are used in warehouse/industrial areas which have a very large air volume and a lot of natural outside air infiltration due to frequent door openings, etc. You would have to check with your local officials to see if that unit would be allowed in your residential garage.
  5. hj
    heaters
    A more or less generic term for them was Reznor heaters, and all of the ones I have seen had vents on them, unless it is an infrared unit, which might get by without a vent.
  6. zimmee66
    zimmee66 New Member
    Feb 28, 2005
    Des Moines, Iowa
    Around the midwest....we call em modines
    we seem to call them modines....
    Funny how generic brandnames reflect whoever grabbed the market first.
Similar Threads: suspended garage
HVAC Heating & Cooling Connecting a new radiant heat zone for a garage slab to an existing baseboard boiler heating system Nov 12, 2014
HVAC Heating & Cooling Converting Garage to living space and water heater/furnace venting req Oct 29, 2013
HVAC Heating & Cooling Garage Heater - Natural Gas - Just installed and flames are tiny Feb 16, 2013
HVAC Heating & Cooling garage door insulation Sep 1, 2012
HVAC Heating & Cooling diy geothermal for garage Jul 19, 2011
