gas pipe size
Discussion in 'Water Heater Forum, Tanks' started by randolph56, Feb 14, 2011.
  1. randolph56
    randolph56 New Member
    Feb 11, 2011
    NYS
    Good morning all. Don't know if this is the right forum but here goes. I want to replace my current 40 gal NG water heater with a power vent model.(AO Smith GPVD40?) The current heater is next to the boiler sharing the flue and about 40' from where I need the hot water. I want to move the WH over to the other side of the house right below the kitchen and 2nd floor bath and vent it thru the foundation. There is a 3/4 gas line that supplies my stove about 5' from where I'm going to move the WH to. The current 1 shares an 1 1/4" feed that breaks down to 2- 3/4" drops, 1 to the WH and 1 to the boiler (both are further reduced to 1/2"). Finally, the question. Does the 3/4" that feeds my stove have enough volume to also feed the WH. or should I increase the size to 1" or 1 1/4"? Any feedback would be appreciated. Thanks
  2. jadnashua
  4. ballvalve
    Dec 28, 2009
    northfork, california
    Sounds fine to me unless its huge range with a grill and 12 kids at home. Try it, cant hurt anything.
  5. hj
    Recommended gas lines sizes depend on several computations none of which you have given us.
  6. randolph56
    Feb 11, 2011
    NYS
    gas size
    Thanks for the replies. After I posted and then did some more searching I realized that I didn't give enough info. From the link I figured what cfh was needed and the capacity/volume of 3/4 with the length and # of 90's etc. So, yes in my case 3/4 will handle what I need, but just to be sure, I called the utility. Thanks again.
    [​IMG]
Similar Threads: pipe size
Water Heater Forum, Tanks Water Dripping From Water Heater Pipe Feb 15, 2016
Water Heater Forum, Tanks Black inky coating in copper flex pipe on hot side? Apr 20, 2015
Water Heater Forum, Tanks Smell from hot water pipe but only until hot water comes out. Oct 21, 2014
Water Heater Forum, Tanks Two natural gas, atmo vent heater b pipe question Sep 27, 2014
Water Heater Forum, Tanks Corrosion on bottom of tank near flue pipe? Jul 23, 2014
