gas line
Cookie
Home
Gas lines on water tanks should they be flexible? Thanks.
I wouldn't lose any sleep over it....but I'm not a pro. Don't think there is anything wrong, though.
Cass
Really, it depends on what your local codes allow. You would have to check with them.
joint
If it was done properly, and your description implies that it was, then it is a flare joint, not a compression one, and it will not loosen, or leak, no matter how much the line is bumped or twisted.
