Gas line through a flue
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Petzold, Jun 6, 2011.
  1. Petzold
    Petzold New Member
    Jun 6, 2011
    Northern Virginia
    I have a chimney with 2 flues for 2 fireboxes. The previous owner installed gas logs in both fireboxes. The gas lines were run outside the house then drilled through the chimney into the fire boxes. On the upper fire box the gas line actually runs through the flue for the lower firebox so that the hot gases pass the gas line. The chimney sweep said they never saw that before and didn't know if that was ok or not. I don't use the fire places a lot but I'm wondering if this is ok or if this is dangerous.
  2. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    Sounds like a bad idea to me.
    One issue is that as the pipe heats and cools the joints are going to expand and contract,
    And with enough movement over time the joints are going to leak resulting in a posible buildup of natural gas in the flew.
    Sounds like a bad idea to me....
  4. hj
    A picture would be interesting, since the gas lines are typically at the "floor" of the firebox, well below the chimney/flue.
  5. Petzold
    Petzold New Member
    Jun 6, 2011
    Northern Virginia
    It is a flexible line so I believe there are no joints going through the flue. Here is what the pipe looks like.
  6. Petzold
    Petzold New Member
    Jun 6, 2011
    Northern Virginia
    I have a fire place on the first and second floor. The gas lines do enter the bottom of both fireboxes however to get to the second floor fire box they ran the gas line through the flue for the first floor fireplace. Attached is a picture up the flue from the first floor fireplace.
  7. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Very illegal, very dangerous, do not use it until someone that knows what they are doing changes it.
  8. hj
    That could be CSST tubing, but I do not see corrugations under the yellow sheath. IF it is plastic it is polyethylene and should not have been used indoors. NEITHER material should pass through the fireplace flue.
  9. Petzold
    Petzold New Member
    Jun 6, 2011
    Northern Virginia
    It's copper tubing and it's not corrugated.
  10. hj
    Interesting. I have NEVER seen "yellow" copper tubing for use in gas lines, and it would normally NOT be labeled for a 2 psi system, unless it was done in the field. Copper for natural gas is not a common item in this area, but no matter where it is used there are specific restrictions on it, one of them being how connections are made. They CANNOT be "soldered".
  11. Tom Sawyer
    Nov 29, 2010
    Maine
    We use clad copper here for LP high pressure lines from the tank to the house but not inside and certainly not through a flue.
Similar Threads: line through
Plumbing Forum, Professional & DIY Advice Running a plumbing vent line through kitchen cabinets Jul 27, 2016
Plumbing Forum, Professional & DIY Advice Through floor supply lines - Anchor or float? 1/2" or 3/8"? Feb 16, 2015
Plumbing Forum, Professional & DIY Advice Best method to reroute 1/2" copper supply line to allow Vent duct through wall? Dec 19, 2012
Plumbing Forum, Professional & DIY Advice 4 Inch PVC Sewer Line Through Cinder Block Foundation Wall In Crawl Space Oct 8, 2012
Plumbing Forum, Professional & DIY Advice Kitchen Sink Drain Line Through Studs??? Mar 16, 2010
