Alvin Flynt
This seems to be working fine with no leaks or problems but just wondering if the use of these methods/materials are kosher. Ran new Nat Gas line to BBQ. Pipes run under 6' tall deck and are attached to underside of deck. at the start i have flexible appliance gas line running from a iron pipe gas stub-out from basement (there since house was built) That flex line goes to a 12' black pipe which has my regulator attached to the end about 3 ft from where I want it to come out on the deck. The regulator has another flexible appliance gas line going to the BBQ on the deck. Used black pipe rather than buying all flex CSST for the whole run as it was not available. I have seen no posts or any discussion on using combinations of flex appliance pipe and black pipe this way. Just wondering. Many thanks to whomever may respond.
