gas hotwater heater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Ed from chicago, Jan 17, 2007.
  1. Ed from chicago
    Ed from chicago Member
    Apr 25, 2005
    Chicago
    Is it dangerous to set the thermostat of my gas hot water heater up to very hot? My wife goes down to the basement and turns it up when she takes a shower, I tell her she should't do this, but she argues that if it was bad, why would they have such a setting. She has a point.
    Thanks
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Danger?
    The only danger is being scalded from the water being to hot.
  4. jadnashua
    To extend the amount of hot water, you can buy a bigger water heater, get one with faster recovery, or turn the temperature up (or all three).
    Turning the water up can be dangerous, but there are ways to have your cake and eat it too - install a tempering valve. This valve is a mixing valve installed on the output of the water heater. You set the maximum output temperature so (baring failure) there is less chance of getting scalded. It basically mixes in cold water to adjust the outlet temperature to your choice. They come (normally) set to 119-degrees F.
  5. GoTanklessToday
    GoTanklessToday In the Trades
    Jan 11, 2007
    Renton, WA
  6. Ed from chicago
    Apr 25, 2005
    Chicago
    Thank you everyone. She seeems to think that by turning up the hot water she can also turn up the cold water, and theefore increase the water pressure...the pressure seems fine to me, but what do I know.
    Thanks again, I was just concerned that perhaps it might be dangerou, other than to the skin.
  7. hj
    heat
    As soon as the hot and cold water faucets are opened far enough to deliver all the water the shower head is set for, about 3 gpm, it does no good to open them any further.
Similar Threads: hotwater heater
Plumbing Forum, Professional & DIY Advice Relocating Baseboard Hotwater Heater Oct 13, 2014
Plumbing Forum, Professional & DIY Advice PEX and hotwater heater Nov 21, 2009
Plumbing Forum, Professional & DIY Advice electric hotwater heater trouble Jan 2, 2007
Plumbing Forum, Professional & DIY Advice Draft hood on hotwater tank Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Redwater Hotwater saving Jan 28, 2014
