Gas hot water heater, problem
Discussion in 'Boiler Forum' started by tommyo, Oct 11, 2009.
  1. tommyo
    tommyo New Member
    Oct 11, 2009
    RI
    Ok I soldered a leak on the one zone valve, this system has 2 zones , one circulator,(I bled system) I fired the furnace back up, the water heats inside to 200f and pressure is about 17psi , I get no heat through the pipes up or down zone, (I even tried leaving zones manually open). does this mean that the circulator is bad, everything else seems to be working fine, damper, evrything eletric seems good, the thermostats triger the sytem, just no heat, I am really baffled, any help greatly appriciated.:confused:
  2. jadnashua
    I think you probably have an air lock. Need to bleed the high points.
  4. tommyo
    tommyo New Member
    Oct 11, 2009
    RI
    reply
    I checked all high points, there are no bleeders anywhere on top floor, it has an automatic air bleeder on top,
  5. msgale
    msgale Member
    Sep 28, 2006
    you might have a slow-operating or non-operating automatic bleeder.
    If you can work fast, you might be able to replace it with a manual bleeder, and that may be all you need to do
  6. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If you have no vents then you must have a loop system and the system needs to be purged. If you can post a picture of your boiler and piping I can walk you through it, or you can call a plumber.
    John
Similar Threads: water heater
Boiler Forum Draining and refilling a Burnham Boiler and Indirect Water Heater Combination Nov 29, 2016
Boiler Forum Advice: choosing boiler and hot water heater Jul 28, 2016
Boiler Forum Feedback on boiler and water heater replacement Feb 9, 2015
Boiler Forum Replace or Repair Gas water heater Dec 8, 2014
Boiler Forum Replacing old NG boiler / water heater - check my sizing please? Sep 6, 2014
