Gas heater making boiling noises
Discussion in 'Water Heater Forum, Tanks' started by LLigetfa, Aug 21, 2011.
  1. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I've got a 3 year old Reliance GSW rental tank - gas - power vent - 6G40NVH-FV-02 - B4743 that has started making thumping noises. Best as I can tell, the water is on the verge of boiling... vapour bubbles form and then quickly condense. It didn't always do this and it's getting annoying. It started after the gas valve was replaced but don't know if it's related. Just one more noise in a long list of noises. Water temp is the same as always.
  2. jadnashua
    Could be mineral deposits...
  4. BizzyBeePlumbing
    BizzyBeePlumbing New Member
    Aug 21, 2011
    Raleigh,Nc
    I would pull the drain valve, install a 3/4" nipple and a ball valve and flush the unit. Jim is probably right, sediment in the bottom of the tank
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Ja, that crossed my mind. I'm thinking that they are probably like potato chips though that flaked off and would not flush out the drain even if I changed it out to a full port ball valve. Probably not as bad as the following classic pic. I've opened the cheap plastic drain and only clear water comes out.
    I found this how-to that calls for a tube to be inserted like liposuction.
    http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
    [​IMG]
  6. jadnashua
    If water can't flow (convection) over an area that is being heated because a little is trapped behind a mineral deposit, eventually it will flash into steam, break through that little mineral bubble, and make noises. The more mineral deposits, the more this happens. That mini steam explosion takes its toll eventually, but is mostly annoying.
  7. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    How hard is the water?
    What is the temp set point?
    I'll take your word for it that this is incipient (or full fledged) boiling with normal conditions. We had extremely hard water when I was a kid and as the oldest I used a long handled spoon to scrape out a lot of insoluble carbonate (retrograde solubility of various compounds) both at home and at the water heater in the dairy barn. Although I did a couple of electric element replacements the tanks were still running when I graduated from college and went my own way.
    Retrograde solubility is a bitch. Magnesium and calcium carbonates actually precipitate as temp increases--the opposite of normal behaviour where most materials become more soluble with temp. If you have soft water , (as I had on moving to Texas) you will be asking: "What the hell is he talking about???"
  8. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I don't recall the numbers but I have hard water. The old State tank sprung a leak after 10 years and it was very slow to drain so I'm guessing it was pretty crudded up. I tried to trip the TPR at the time thinking I'd break the vacuum to drain faster but it turned out to be all crudded up and wouldn't move.
    Not sure about the temp set point but it is higher than the default. A 50/50 mix of hot and cold is about right for filling the wife's soaker tub.
    I did the math and figured I'd break even renting versus buying if it only lasts 10 years. The only thing I didn't think through is if it lasts much longer and fills up with scale like the pic above and the rental company doesn't want to replace it. Then I'd have to cancel and buy a new tank or go tankless.
  9. jadnashua
    If a tank gets that full of deposits, it wouldn't provide much hot water and that alone, rather than a leak, should consitute a valid reason to replace it. You'd have to read the fine print carefully, though.
Similar Threads: heater making
Water Heater Forum, Tanks Water heater making strange noise Jul 27, 2011
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks HW Heater to tankless coil Feb 13, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
